Xiaomi Redmi Note 5
Wishdom
Don't get confused btw China Variant and China ROM. This is the China Variant (in HWZ lingo) i.e AI Dual Camera but yours is preloaded with Global ROM.
Technically it should be Redmi Note 5 AI Dual Camera: https://www.gsmarena.com/xiaomi_redmi_note_5_ai_dual_camera-9120.php
The ROM depends on which country it is being sold. For unit sold in China, they are preloaded with China Rom but outside China, Global Rom.
What's the main difference between China variant and the normal variant?
Sent from Ilovennp using GAGT
osmond19
JTBC now offers the cheapest export set on Shopee but it's on China ROM and you need to be prepared to wait a while as they don't have ready stocks.
Hitec offers the 4+64 export set at $280 on Shopee and it's on Global ROM.
China ROM means no play store? If so, how to use in SG?
osmond19
If that's the case what's the difference between China n global rom? Can I flash from China room to global rom myself? I know OnePlus can flash from hydrogen os to oxygen os easily. Same for XM?
alanlimct
The set I received is a sealed unopened set . Don't think they open up to install. Is it already install in the factory ?
JTBC will preload Google Play Store on the device, but it will be running MIUI China ROM instead of MIUI Global ROM.
silverstar
btw, ty for answering all our questions. interested in getting one but was worried abt the 30 day pre-order thing.
alanlimct
Give them a call first before order. I call them before i order and was told the stock will arrive in one week time . I received my set around one week after order . Try not to message them , they took day to reply message .
Anyway , they got a physical shop in orchard road far east shopping center . Any problem can go down . Don't expect any good service from this type of import shop . If the price is good then buy .
If can wait then buy , if not better don't . They can promise you everything . End of the day, if they cannot fulfilled your order . They will just cancel it , like one of the member here kana .
osmond19
I just to Google n realized that XM bootloader has anti zone feature. It does not allow China rom to be changed to global rom. If u did so, u must only keep the bootloader unlock. If u lock back, it will soft brick the phone... Wtf. XM dun support flashing....
How to tell it is running China rom instead of global rom?
osmond19
If u are running China rom, does all Google services will work beside play store? When a new room is out, is the play store still gotta work? Seems like global rom is a safer bet.
alanlimct
Possible . It just a normal seal . Then they must be very hardworking to do the resealing and cleaning on the phone . Haha !
Anyway the miui version is miui global 9.5 stable 9.5.6.0(oeimifa)
I got problem attaching the screenshot here .
My previous import set come unsealed and with finger print all around the phone .
They could do the resealing easily. :o
alanlimct
To me , nothing different except got some China app which cannot be uninstall . Everything work fine .
My previous redmi note 4 had been running on China ROM for month before i updated to gobal ROM . However I don't find much different .
Anyway China ROM can update to gobal ROM anytime when it is available . You can do it yourself or the shop can help you .
If want peace of mind . Get the local official set .
Maybe expert here can advise .
osmond19
The older version of XM can unlock bootloader to flash to global rom and lock back the bootloader but seems 5 series onwards, u cannot lock back the bootloader. Without locking bootloader, Android pay will not work even game such as Pokemon go will not work. But u are welcome to the dark side of flashing custom roms and hacks...
alanlimct
My redmi note 4 bootloader was unlocked and never lock back after flashing gobal rom . However I still can play Pokemon go . No sure about note 5 thought .
amazingone
Global ROM?! :eek:
FreshGradDays
Now can upgrade to Global 9.5.13 already
