Xiaomi Redmi Note 5
Geo
I called up JTBC earlier to check on the ETA for 6/64G Black and Blue and I also asked them to confirm that they units they bring in are China set preloaded with global rom.
They told me they are bringing in are China set of Redmi Note 5 AI Dual Camera preloaded with China rom by default so they requested their supplier in China to flash it to global rom.
However, only some batches were flashed to global rom while the rest are still on China Rom. I guess those make purchased and received sets with global rom must have hit jackpot :s13:
amazingone
Xiaomi Mi A2 (Mi 6X) is out. With SD660.
https://www.gsmarena.com/xiaomi_mi_a2_(mi_6x)-9140.php
No microSD card slot.
About SGD$292.
Mi Max 32GB HardwareZone Forums app
There's no official launch of Mi A2 yet....
amazingone
Like that is see heng suay if the set is Global ROM preloaded or not. :eek:
Geo
For experts in this forum like you flashing is not an issue but for me, is a daunting task :s13:.
That's why I prefer it comes with preloaded with global rom or at at least the shop does the flashing for me.
But den again u can always flash global rom.
Wishdom
So what's the eta? I ordered on Friday night..
Sent from Ilovennp using GAGT
amazingone
For experts in this forum like you flashing is not an issue but for me, is a daunting task :s13: .
Same, I prefer it coming with Global ROM preloaded, so can save myself the hassle of flashing it and also the possibility of bricking it if flash wrongly.
Just Me
All Redmi boxes are packaged with a Red outer packaging, and a White inner packaging.
Then the one which bro hoon_ki with white box (32gb JTBC set) is china variant but still the AI Dual Camera model?
Hailgod
wew please stop asking the same questions.
Export sets marketed as whatever redmi note 5, redmi note 5 pro, will be china rom, typically with playstore installed by reseller.
Exported global version will definitely be marketed as global version, if it isnt from xiaomi directly.
they have global rom by default.
usually there would also be china export sets but with global rom. it doesnt look like its going to be common this time because the bootloader has to remain unlocked after flashing it, or it will go into a boot loop.
Sent from Xiaomi REDMI NOTE 5 using GAGT
amazingone
Yeah, so getting export Global set with global ROM should be better I feel.
rabbit1
those who wants volte dial *#*#86583#*#* and change to hong kong region and reboot.. tah dah!
hako92
Flashing is easy, just follow the steps. Unless you tell me that you can follow simple steps. Just go to miui forum, the community jin helpful one. They got sotong guide for noob.
