Xiaomi Redmi Note 5
Sambuca78
I've used 3 sp from them, going to apply another one soon. No halo in the centre. Could be due to oil residue.
For the 2nd sp, I didn't just get a think halo margin, after applying for a few days, the halo on one side "eats inside" a little bit (a small round curve inside). I cannot understand how this can happen since the glass is flat. If I didn't clean properly, it should appear very quickly and I would have reapplied if possible.
After sometime, the phone was dropped. The sp cracked starting from that spot. So I gather that the sp is defective and weak at that spot.
Reason why I still buy from them is that they are cheap. I bought a $10/- sp before and it cracked at the earpiece cut out. So I can't tell whether cheap or expensive sp are good or bad.
I bought Nanotech (Nanotech) and Sapphire (Maxtech) before which I didn't have problems. But they don't have Redmi sp.
Ok ok, u sound satki in SP. :D
If that the case, I will get the Full Cover(black). :D
Model : Xiaomi Redmi Note 5 / Pro
Type : J - 0.26mm - High Clear Full Cover(black)
Color : Black
Nakedtoes
Anyone know how to disable notification for android system (*** is displaying over app)
I always use pie control and volume slider, i tried o disable the notifica ion but it was grey out/locked
I also love pie control been using for my past 4 phones.. the only apps i cant live without.. big screen 6.4inch or small screen.. 6inch.. another thing is cannot disable and hide the buttons below if can is superb
crunchyflakes
Color : Black
i used many TSP for all my previous XM phones... this is the only SP i used that had this "halo". I think its due to the tempered glass being too thin i.e. not completely flat
else why else wud there be this... cos when i used another, no halo. (i have 2 RMN5 at home) but its not full cover
anyway i bot a carbon fibre to try... lets see
KYLee
So redwhite mobile is confirmed local warranty set by xiaomi?
xpherta
M1803E7SH is which country's set?
Edit: does it make a difference if the sets is meant for different countries?
xpherta
lohsenglte
Your link says "Local seller warranty 1 Year", not XM leh ?
Nakedtoes
For me black any time.. But no doubt other colors is nice also.. So far bought 2 black, 1 gold and 1 blue..
pilico
Anyone finds that the rn5 photos sre not sharp ?
I tried to compare with mi max, mi max is way shaper than rn5.
