Xiaomi Redmi Note 5
garychengjw
Bought from NewStars and using Note 5 6GB version. Very snappy and the camera is surprising good. Just only the portrait mode is very fake looking.
I'm on China ROM. Not sure if Indian Note 5 Pro ROM can be flash onto it.
Sent from Xiaomi Redmi Note 5 aka Note 5 Pro using GAGT
Dorkable
How much is the 6GB version from NewStar?
tomb
This may be a good read to clear up the confusion!:s8:
http://en.miui.com/thread-2151903-1-1.html
the review stated that "unfortunately after testing with 2 different QC 3.0 chargers, the maximum amperes is 2.51, therefore this falls under QC 2.0 only. Our maximum intake for Redmi Note 5 Pro India was 2.32 Amperes".
is the part about QC3.0 current true? from what i've read, it seems to be more about optimisation of voltage. anyway, should be able to test charging times using QC2.0 and QC3.0 chargers.
Hailgod
lol even rom between mi3 and mi4 can be flashed when they used the same codename. A "Device Team" on a forum that thinks 1.25 micron pixels is better than 1.4 microns can be trusted now?
Sent from Xiaomi REDMI NOTE 4 using GAGT
Dorkable
As one of the early adopters of the Redmi Note 5 China, I did share previously here that I also felt the charging speed was only at QC 2.0 max, after carrying out the charging test using my Anker QC 3.0 charger and Verbatim QC 3.0 compatible cable :(
garychengjw
I suspect it's the hardware chip (i.e. network and camera). Even the shop in collected from warned me not to.flash
Hailgod
reminder that note 4x has 3 different back cameras, and every chinese variant has different band support from global variants.
Global rom worked on all of those.
hell mi3 and mi4 had different SOCs and it worked.
qwerty1981
I just ordered one. Seller asks whether I want to do a quality control check and rom flashed to global or I can choose to leave the seal intact. Which is the better choice?
simplemiii
Hi all, i am about to get thr mi 5 plus till i see until the note 5, can check with you all, China set that is flash to global is the same as local set where i can update the phone normally in the setting? And is the price consider ok at $384 if i order from newstar 4/64?
