Xiaomi Redmi Note 5
ktyandkyc
The basic lineage oreo first. Ideally I want a rom with built in privacy guard. It has option to prevent auto app startup on boot, prevent keep awake and prevent run in background. I get really good standby time on my mi max with privacy guard.
Oh saw ur previous reply.. u manage to flash so fast?!!
yusoffb01
no i have flash anything. still china rom. not sure if eis works on lineage so didnt flash yet
Hailgod
To all current user of note 5, just a few qns I would like to ask is that :
Does it have wifi 5Ghz AC as stated?
Dual 4G on standby?
5ghz wifi. cant test how fast it goes since my router maxes out at ~300mbps on every device.
Hailgod
Any problem so far? Update already camera better battery life got worsen?
Came pre-installed or u zhng de
no idea, just received it and OTA straight to the rom.
Battery life still very good though. used 45% in a working day with ~2h gaming and ~1h reading novel. Brightness was on Auto. The screen goes much brighter than redmi note 4x and is easily legible in daylight as well.
Just Me
Finally tried flashing the leaked global rom. My first time flashing roms...was actually quite simple. Global rom seems to use less ram compared to china rom.
Definitely.. cheena rom has a ton of useless bloat and spyware
hyper_megaman
Yes I'm getting heaps of nonsense notifications
If I flash global ROM leaked version, will it support OTA updates in the future when they officially release?
Hailgod
did u not debloat the chinese rom?
Uninstall all the preinstalled app then set everything to google as default.
yusoffb01
Managed to unlock phone without waiting for 360 hours On china stable rom. The trick is to use 2 accounts.
Both accounts must have applied for unlock permissions. http://en.miui.com/unlock/
Login first account on phone, Settings > Additional Settings > Developer Options > Mi Unlock Status. Tap on “Add Account” to bind to phone. Also enable OEM unlock option
Restart to fastboot (hold volume down + power button)
Using mi flash tool, login to first account and try to unlock, you will have 360h timer.
Restart phone, sign out of miui and login to second account, but DO NOT BIND PHONE. Then restart to fastboot
Login to second account on mi flash tool, then unlock will be successful without timer
ktyandkyc
Can one account use mobile number as username while other use email address? Thank you for sharing
ZrE0_Cha0s
Wah nice guide btw. To skip that stupid long waiting time XD
Force89
Those getting this phone can consider the Nokia x6 which would be announced today! Both have similar specs.
Sent from Xiaomi REDMI NOTE 5 PRO using GAGT
yusoffb01
Finally managed to get 4k recording with stabilization, the main purpose of buying this phone...
If you want to get this, after you unlock phone, download this file https://drive.google.com/file/d/10vGz1Fb7l9YIIKz3Alcrano4vUxa6yua/view?usp=sharing
0) copy the magisk.zip into phone
1) reboot to fastboot (vol down + power)
2) after you unzip, press shift right click mouse, open command window here
3) copy and paste the following into command window
fastboot flash recovery recovery.img
fastboot boot recovery.img
4) In twrp recovery, reboot into recovery again. Somehow after flashing if you dont manually try to boot to twrp recovery, the default xiaomi recovery is booted
5) flash magisk.zip
6) reboot phone, go play store search for es file explorer or any other root explorer
7) Go to /system/etc/device_features/whyred.xml
8) Find the line that says "support_camera_4k_quality"
9) Change the >false< to >true<
Now you can open miui camera app
Nakedtoes
same price at abt 200? same camera f1.9? same battery capacity 4000mah?:s13:
windwaver
Bro, you use same phone number for 2nd account?
kengwee95
Some of us bought the price is even cheaper then what they sell at China retail price.. Dun ask me why.. I not sure also.. 32gb/3gb is retail abt 239 sing, 64gb/4gb is abt 297..so any prices below this is best buy.. Like the recent 32gb/3gb can buy at 204 and 64gb at 269..the lowest so far
I thimk got bulk discount?
Nakedtoes
What is to be expected for redmi note 6?
Dun expect much. Infact recent studies show mobile phone sale is super stagnant.. Except xiaomi and Huawei growth the rest drop.. It is to show that if no more new technology the market is getting worse.. Phone of 1 2 years ago still very powerful.. I m still using mi mix.. 2016 flagship and no see point of changing phones. That's why u see some scam company purposely slow down yr phone to let u have fake impression the phone is slow need to change.. U know which coy hor?
kengwee95
The fruit company ah?
