Xiaomi Redmi Note 5
Audiology93
SIC good deal. Cheapest Redmi Note 5 for $199 for 3/32. $239 for 4/64 and $289 for 6/64. It's on Shopee. Seller JTBC.
Edit: ok someone shared it already :s13:
Sent from HUAWEI MATE 10 using GAGT
Sambuca78
Tempted... waiting for the local set till neck long long le. :(
kinderbuenojhj
stop spreading fake info. hk carries global 6gb rn5
Sent from Xiaomi REDMI NOTE 5 using GAGT
Oic.
Thanks for the verify bro.
OK guys, chiu all have heard it. There is a 6GB Global Version afterall.
For those wanting that, pls do get the HK one.
Chop + confirm by Hailgod.
ZrE0_Cha0s
But this is india set? They stated the specs wiith 20mp on the front.
kinderbuenojhj
32gb/3gb for 194, 64gb/4gb for 234 and 6gb/64gb for 284..
Get a set of black 64gb to use as spare or maybe main phone..:s12::s12:
From JTBC shopee.. after using $5 off coupon
definitely... but do take note that set is export set and JTBC offer 6mth warranty.. they have a shop in singapore. set likely is china set and using china rom... likely JTBC will install playstore already just like when i bought redmi 5 plus from them during jan feb...just uninstall all those useless china apps in china rom and u are good to go... not necessary die die must use global rom ..;) cause usually china rom get updates quicker and got more features which global dun have.. but global is default have goggle service playstore etc
Oic, no wonder it's cheaper than the Global Version.
Smart of these ppl, get the cheaper set with Tiong ROM and then flash global rom into it.
Rike dat they can stop the producing of Global Version riao.
:D
Hailgod
:D
thats how all the resellers work. which is why all the boxes are not factory sealed but resealed by resellers.
We dont use band 20 here and nobody can even tell the difference between the 2 versions once the reseller installs global rom.
kinderbuenojhj
We dont use band 20 here and nobody can even tell the difference between the 2 versions with the same rom.
:eek::eek::eek:
Is that the same goes for the HK 6GB one ?
It's actually a Tiong set (originally with Tiong rom) but the reseller open it up and flash global rom into it ?
No wonder chiu keep mentioning there is a 6GB "global version" in HK.
:s13::D
kinderbuenojhj
Careful bro.
India set - They call it RN5 Pro.
Tiong set (include Global Version) - Tiongs call it RN5.
Moi at first abit confused too.
But moi differentiate the 2 by its front cam.
India got 20MP front cam while Tiongs got 13MP.
ZrE0_Cha0s
Careful bro.
Well India set now can flashed to global as well.
amazingone
This is China set or Indian set?
If it's China set, the price is very good! :s12:
Dorkable
Thank you FreshGradDays, Bloodlamb and Nakedtoes for providing the bits and pieces of advice in my first attempt yesterday to flash the Global ROM :)
I succeeded!
Now my 6GB Magic Blue RN5 has the latest Global ROM and working great! :D :s12:
lls8450
I succeeded!
Can you provide a step by step guide on how you flash the global rom?
Dorkable
Actually, my Senpais already did, hee. Only thing I did differently was I chose the option "Clean all" only during my Flash stage.
I did it myself all the way from binding phone to account, install Mi Unlock for unlocking bootloader, download and use MiFlash to install WHYRED 9.2.7 Global rom, unlock bootloader again, update to global 9.5.6 rom. This was my first time and took quite awhile to research how it was done properly. Luckily still succeeded though all files lost without backup
Correct me if i am wrong.
Step 1:
Install MiUnlock to unlocking bootloader
Step 2:
Use MiFlash to install WHYRED 9.2.7 (this is to make it to a lower ROM first)
Step 3:
Install MiUnlock to unlocking bootloader again
Step 4:
Use MiFlash to install Global ROM 9.5.6
Hailgod
:eek::eek::eek:
:s13::D
i think you are clearly mistaken. hk isnt china. hk needs google services. hk needs global rom. hk has 6gb version with b20 on sale.
all of these info can be found in xiaomi hk website.
Nakedtoes
Actually the China sets is not cheap.. It retail abt 231, 294 and 357 for the 3 models 32gb,64gb/4 and 64/6..so any price below the above is goo price
