Xiaomi Redmi Note 5
ZrE0_Cha0s
Bro got place the sim wrong side up?
U got click the dual 4G option?
Edit to include my 2nd SIM inserted
Thanks for confirming this is working. But may I ask how u tested like the data while making calls? Does the data falls to 3G? For both sims as well?
Hailgod
thats volte. most xiaomi phones are not officially volte supported in singapore. Some are able to hack it into working but the default settings wont work.
Deathzz
my notification don't always pop out, whatsapp and line. need open then update. my previous note 4x was fine. even after offing miui optimisaiton also same effect
kinderbuenojhj
Just realised (moi abit noob here) the 6GB ram edition is only for the Tiong set (red box, non-global version). Not sure tho for the Indian model if it carries 6GB ram edition too.
So for those aiming the 6GB ram variant, do be caution. Unless you dun mind Tiong set. Those ordering online eg. q10, lazada etc look carefully first dun just suka suka take the 6GB option.
RN5 (Global Version) max ram is 4GB nia.
RLWZ21
how much did u bough for the 6GB? and current where to get the cheapest for 4GB and 6GB? (would like to compare the price. :o) TIA
Dorkable
Xiaomi has been doing a fine job of confusing everyone, hee.
Anyway, the Global set with 4GB but with China variant camera also comes in a red box, and the box will indicate "Global version" on the side.
kinderbuenojhj
thanks for the advice, I hoot already. Will post a seller legitimacy update once I get it!
Can post some unboxing pics after chiu got it ?
Most probably you would get from April batch (in small print at below right corner back of the box).
But if you lucky enuf, you might get from the latest May batch.
kinderbuenojhj
Yup, that's the correct one to get if chiu dun want a "Tiong Version".
kinderbuenojhj
I din bought the 6GB.
Lucky I did some googling and asking around homework first.
Think the current cheapest for 4GB is ard $270 - 300.
For 6GB think ard $350 ba.
Just moi guess nia.
:o
kinderbuenojhj
I asked mi Singapore on Facebook
No reply yet
It’s sad Singapore is an insignificant market for them
Beside they know how to post rubbish, they won't be bothered with SG market. Even Philippines has been dead, but Redmi Note 5 make it alive back. They have been dead after Mi 4i times till recently it started to be alive.
I think maybe soon they will launch the RN5 here officially.
Saw on their websai and MI Store at Bedok they already selling the Redmi 5/Redmi 5 Plus.
Hailgod
stop spreading fake info. hk carries global 6gb rn5
Sent from Xiaomi REDMI NOTE 5 using GAGT
hawke
Google Playstore Error code 0
Hi guys, i just gotten my hands on a Redmi Note 5 32gb. want to try it out. try the new chipset whether can play games smoothly
unfortunately i can't even install apps like critical ops and PES 2018. after about some varying percentage of downloading, it just stopped.
i can install smaller files like WhatsApp and so on though.
hope can get some guidance from the gurus here.
best wishes
hawke
Anyone offering flashing service? from the chinese ROM to Global ROM. i am a mac user, dun have a PC
FreshGradDays
I did it myself all the way from binding phone to account, install Mi Unlock for unlocking bootloader, download and use MiFlash to install WHYRED 9.2.7 Global rom, unlock bootloader again, update to global 9.5.6 rom. This was my first time and took quite awhile to research how it was done properly. Luckily still succeeded though all files lost without backup
Hailgod
Correct, 6G ram is the chinese set, with Miui 9 chinese rom, and no google play installed. You have to install the google play yourself, or try to see whether the global rom can flash into it.
no. theres 6gb global.
Dorkable
Why install WHYRED 9.2.7 Global rom first? I thought we have to downgrade our latest China rom V9.5.14.0 to V9.5.4.0 first before upgrading to the latest Global rom?
Edit: Oh I think I get it....coz you have to downgrade to 1. Global Rom AND 2. an older version as well first before you can upgrade to the latest Global Rom :p
