Xiaomi Redmi Note 5
hawke
I did it myself all the way from binding phone to account, install Mi Unlock for unlocking bootloader, download and use MiFlash to install WHYRED 9.2.7 Global rom, unlock bootloader again, update to global 9.5.6 rom. This was my first time and took quite awhile to research how it was done properly. Luckily still succeeded though all files lost without backup
Correct me if i am wrong.
Step 1:
Install MiUnlock to unlocking bootloader
Step 2:
Use MiFlash to install WHYRED 9.2.7 (this is to make it to a lower ROM first)
Step 3:
Install MiUnlock to unlocking bootloader again
Step 4:
Use MiFlash to install Global ROM 9.5.6
Questions:
1. Why can't i skip step 3 and 4? ** Edit: got it from the following post. need to downgrade first.**
2. Does the global rom comes with Google Play Store?
Nakedtoes
32gb/3gb for 194, 64gb/4gb for 234 and 6gb/64gb for 284..
Get a set of black 64gb to use as spare or maybe main phone..:s12::s12:
From JTBC shopee.. after using $5 off coupon
Dorkable
Did you by any chance encounter this error during the first Flash:
"can not found file flash_all.bat"
I unzipped the WHYRED 9.2.7 and Flashed from that folder and got the above error.
bloodlamb
You need to find the fast boot ROM to flash. It should be a .tgz file.
I think the zip file is recovery ROM. Just did it 2 hours ago.
I have one problem, the device can boot after I flash it with clear all and lock bootloader. Have to unlock the bootloader again using the tool.
Sent from Xiaomi MI MIX 2S using GAGT
Dorkable
I see. Thank you! :)
FreshGradDays
Yes, I tried to do 9.5.4 global rom directly but it wouldn't work as they needed an older version so i flashed 9.2.7 first then manually update later.
For the 9.2.7 tgz file you have to use WINRAR achiever to extract it, then use Miflash to flash it via bootloader
Nakedtoes
Is this better than mi5 32/3G? Thinking of upgrading my mi5.
definitely... but do take note that set is export set and JTBC offer 6mth warranty.. they have a shop in singapore. set likely is china set and using china rom... likely JTBC will install playstore already just like when i bought redmi 5 plus from them during jan feb...just uninstall all those useless china apps in china rom and u are good to go... not necessary die die must use global rom ..;) cause usually china rom get updates quicker and got more features which global dun have.. but global is default have goggle service playstore etc
bloodlamb
I meant cannot boot with locked bootloader. Have to unlocked then can boot. I go straight to 9.5.6 from the China ROM
RLWZ21
but may i know is there any shop selling at the similar price in qoo10??? and for shopee how u get coupon?
but for 50 bucks difference btw 4 and 6 gb worth it?
Nakedtoes
When flash I remember instruction is clear all and dun lock.. Else might brick the phone
Nakedtoes
Nope Q10 32gb is 239 already best price is 219 after coupon. OS use abt 1.5gb ram so 4gb left abt 2.5gb and 6gb ram left abt 4gbplus of free ram... More ram means u can load more apps in memory.. Depend on what apps.. 4gb can store abt 15 to 25 apps in memory and 6 GB can store over 30apps..3gb can store less then 10 apps.. So judge for yrself..
Just Me
Is this china set? Can flash global rom right? Heard the 6gb model has no global rom yet. And how come it's almost $50 cheaper than qoo
Nakedtoes
Yes.. I checked with seller. Is china sets.. I dun see a need in flashing global rom.. So u check with other bro who have successfully flash.. I might flash but I heard global rom is buggy now..
Just Me
HK sets also come with global rom so I suppose it's not much of an issue.
SpeedWeed
Quite cheese pie
They open more mi store franchise
But no launch redmi note 5 凸
Beside they know how to post rubbish, they won't be bothered with SG market. Even Philippines has been dead, but Redmi Note 5 make it alive back. They have been dead after Mi 4i times till recently it started to be alive.
RLWZ21
but how u get $5 dollar coupons?
