Xiaomi Redmi Note 5
Hailgod
I have the China set 3/32GB and unfortunately i'm facing the delayed (or none) notifications from WhatsApp/Airbnb etc unless I open up the app.
tried setting these apps to autostart and disable battery saver but not working. seems like a common issue but only affecting certain users only.
my mi max2 on Android 7.1 has no such issues (as I migrated from Mi Max 2 to RN5)
lock the important apps in your ram.
Hailgod
Just tested QC using the mi powerbank 2.
phone was on idle but not off.
from 20-80%
20% - 00min
30% - 11min
40% - 18min
50% - 25min
60% - 31min
70% - 40min
80% - 50min
For comparison, the p20 pro got 20-80% in 47min while in a shut down state.
mi6x does 1-80% (2400mah, same as 60% of 4000mah) in 45min with a qc3 charger.
assiak71
Read the Mi A1 thread and saw one guy posted this,
'For Head ups. Just back from service center, the service officer checked my imei and yes it comes with local warranty even set delivery address is from Malaysia.
And they said that if set delivery address is with malaysia, Singapore xiaomi will still bear the warranty.
Phew. Thank god'
Means redwhitemobile at 298 for 4/64 is current cheapest with local warranty?
Pocoyoz
But rwm don't have blue colour set?
Sent from Pocoyo fan club using GAGT
Ultimo_Urien
Beginning to ponder if getting N5 is a worthy upgrade over Mimax 2, afterall we get what? better display? better cam+the SD636 but sacrifices on the USB-C, smaller screen and a lower battery endurance?
kinderbuenojhj
I want to say. I'm really impress with the knowledge the people here... you all really know so much while most of us just regular users and rely on you all when we need help. :)
You'll be more "impressed" by the no. of ahbeng shop runners/hp shop operators, dealers etc in disguise here.
kinderbuenojhj
Imei or SN is on the box also ? Maybe can even test on the spot before opening the box if seller claim xiaomi SG warranty. If true, seller should not object, right ?
Better than finding out no xm sg warranty after half a year
Think they will not object.
They will just insist and repeat that local warranty is covered. These ppl are trained to keep repeat the same thing.
Up to you to believe what they tell you (until the day your fone is really spoilt within the warranty period and you send it down to its svc ctr).
Like the other guy mentioned - Buy dun scared. Scared dun buy. Want true piece of mind, then go to its official store buy.
I just bought from rwm and the result says Malaysia hahaha.
Paid 298 for a black 4/64
Not sure. They guys at rwm was quite sure it's warranty is covered by xiaomi local..... Hope nothing goes wrong... I have full receipt to back up the purchase.
Anyway, the power adaptor fromnthe box is a 2 pin type and not the SG 3 pins. Just wondering what 4h3 configuration if anyone bought from local xiaomi shop (suntec)?
kinderbuenojhj
Phew. Thank god'
Well, moi can only say if what that guy said is true then XM has really pwn itself by its own statement below.
As usual, check with MI SG personally to double confirm.
https://www.facebook.com/XiaomiSingapore/posts/1992414680799623
How do you know if you're purchasing an official Xiaomi phone?
1) Find the IMEI number (see how to below)
2) Click on the link and key in your IMEI number: mi.com/verify/#imei_en
If your delivery address states "Singapore", then it's eligible for warranty at our service centre!
kinderbuenojhj
Wah..... That's nice to know.... Hengz arh.... Rwm has just got back to me and they are very sure it's covered by xiaomi Singapore. I'm have no problem with the phone.. Its good.
Very nice of MI SG indeed.
They dun mind help cover warranty even tho the set(s) are "imported" from bolehland.
That's what a good neighbour is all about.
Deathzz
i reflashed everything to global rom, now works fine
zirdaj
You managed to overcome the 360 hour wait? I can't even login my mi account on my phone.
I have a couple of issues with my phone:
- Pokemon Go can't detect GPS (GPS set at high accuracy and the necessary permissions have already been given)
- Can the fingerprint scanner be used to remember passwords? So far mine is only used for unlocking the phone, and I do not now how to use it for other things (running stock China ROM)
Sambuca78
Shouldn't u be checking with Xiaomi Singapore instead of RWM?
amazingone
You can also use the fingerprint to lock apps too, if I'm not wrong.
cscs3
Local warranty is just a trick. It can be shop warranty. What you want is agent or manufacturer warranty.
More then often, manufacturer warranty is always there. Even you get a parallel importer set, you can always send back to claim warranty if cost of shipping is not a concern.
jas1701
Bedok Mall has an outlet for Xiaomi. I bought the 10k powerbank and asked the staff if it is original and they said it is. Anything wrong after 7 days send to clark quay service centre.
Base on their website store locator, bedok mall is not in the list. Siao like kena con.
http://www.mi.com/sg/storelocator/
amazingone
The Mi Store at Bedok Mall is an authorized one, as per Mi Singapore's Facebook note:
https://www.facebook.com/notes/mi-singapore/list-of-authorised-mi-stores-mi-zones/1985442334830191/
csc12345678
The fingerprint is another form of authentication. Yes, I've tried unlocking apps (ie OS level). Also, some apps, eg Paylah also use it as an alternate authentication (ie inside the app).
