Xiaomi redmi note
metaldagger
Hi under the power usage , android system mine is always between 50% to 90%
I hardly use it, just sms , viber and games like COC
Is this normal?thks
Johnteoh
Hi do you guys use the clean master app with redmi note? I use it on my Samsung note 3 but I noticed the redmi note has its own clean app built in the security app, it says powered by clean master? Would installing clean master add more ram usage?
Possible and take up storage space too. The default one is actually quite good so I don't see the need to install another similar app.
halocast
My Google map cannot point towards the direction I'm heading...
no such issue for me.
yr gps is turn on right? are u indoor or what?
maybe yr gyro or compass not working. try the compass app inside tools and see if it works properly :s12:
halocast
I have a whole lot of 1.2gb in miscellaneous files under storage, i can't clear it. May i know how do i delete them? Other android files will have a dropdown list to clear them. But Xiaomi note do not have.
Please help :( How to clear them?
go under security app, then cleaner. :s12:
halocast
default one seems good enough :s12:
furyoo
To be honest, Android doesn't need ram cleaners. That's not how ram is managed in modern OS anyway.
furyoo
BTW there is a new ASOP ROM. Looks and feels faster. At least the rotation seems to work better.
koroshiya8
Anyone using the official redmi note flip case that can be bought from xiaomi website.. and the application is just stick on the phone.
【Redmi Note Wallet Flip Case】Xiaomi Singapore Cases details
can the phone really stick on well to the flipcase? will drop a not?
They have this type since Mi3 and i tell you the designer is making a huge assumptions that people will not change casings... once u stick this on it's a real hassle to remove it if u are the type to change casing frequently... of cos it has it's pro...
lamerhood
Does u guys have issue on the network ? Mine note keep changing from 3g to h+ to h... Issit normal ?
kopi22
i plan to buy that phone, anybody use before, how is it? good anot?
Don't expect to have performance like those branded ones. The performance is just average. I experienced lags here and there when playing with my friend's XM Note.
