Xiaomi redmi note
timpeh82
Realise something about xiaomi delivery. They go by loyalty points i guess.
My 1st 1S waited around 8 days. 1st note waited 6 days. then 2nd note waited only 4 days.
Any bro have the same encounter?
hyper_megaman
i've bought stuff at over 10 xiaomi sales
my phone from last week is still delayed
no pattern la, just fedex too much to deliver, bo chup
kweeli
this may ask before...
1. can anyone share what photo apps use to enable photo save to sd?
2. how to more apps to SD?
Thanks
eddy2099sg
Thanks
For Camera apps, I tried Camera 360, Line Camera and A Perfect Camera and all allows you to change the location of where you want to save the photos including the SD.
Alternatively, you can apply the patch from Save photos and videos on SD-card - Redmi Note - MIUI Official Community , although it said it works with v25 only, it does work with the current version.
You can move the apps to the SD card but they will not work from the SD card.
rollbread
I ordered on the 8th and initially tracking put delivering on 13th which is today. Then when I check again, it changed to N/A. :(
stonefish35
Camera Zoom FX works too. And if anyone using the selfie stick with BT remote trigger, will need the Camera 360 app too.
I dont see it as an issue. Just use diff app. THe default camera app isn't fantastic to begin with ...
halocast
the default cam can work with the bt remote trigger :s12:
coldmilk
How much is the shipping fee to Singapore?
Not very familiar with the chinese words, but how to search for Samsung S4 too? :s12:
My Chinese also half-past-6! I order thru 65Daigou which is a Singapore based website which specialised in ordering from Taobao. Slightly more ex but so worth as it is less hassle especially for the Chinese-challenged individual.
I used google translation to help me read their website in Taobao. Not perfect but good enough for me to understand.
I used sea-freight as I ordered multiple items. Cost is $4.7 for the 1st 500g, and then $1.70 for the next 500g and thereof. FYI, two of my films weigh about 100g combined.
Glass film for Samsung S4;
http://detail.tmall.com/item.htm?sp...910134014&rn=35975478c5651fb28df420adbf9413c4
coldmilk
if dust stick on the screen protector. just use some scotch tape to extract the dust, be it on screen protector or phone. it works well.
thats how i do it on any mobile phone. u can see outside shops also using the same techniques
This is what I did, after the initial failed attempt.
One advice for everyone; whatever you do, please not not try to wipe the dust off the underside of the film. It will get worse:s22:.
prince_kael
Go down to Clark Quay the central 4th floor. If one month I don't know how they would repair or replace. I received my note today and straight out of box, the screen bleeding problem and faulty. Went there, they ask for my phone no and name. In Less than 5mins I walk away with new mi note. Looks like warranty is base on buyer name and no. If the bnib note go through many buyer and they resell and finally one buyer decided to use it and suay suay find out phone got problem. Then die laio. Confirm need to trace back the original buyer to claim warranty as they straight away registered the device imei when someone buy and registered it to their number and address and name.
How to check for screen bleeding?
kweeli
Dun understand what is xm strategies... Even the old samsung s2 allow to move some apps to sd n can open the apps from sd too. Yet xm new phone can't do that. What the constraint?
eddy2099sg
The constraint is Google, if I recall correctly, somewhere around the Android 4.2 release, Google remove the ability to run apps off SD cards. Their own designed phones don't even have the SD slot to begin with.
Of course, you can circumvent that through rooting the phone but it is no guarantee as to the stability of running off the SD card.
Xiaomi phone is not the only phone which faces this limitation.
kweeli
Thanks for the explaination...
GGsg168
anyone can help ?
my camera360 ultimate unable to use, when open, it read : "Fail to launch the camera. Please retry or reboot". :(
Andrewtst
First try on Redmi Note Real Camera.
Kinetic88
some thing weird happened to moi Note. The display kept on appearing even moi switched it off during charging.
It had never happened b4.
