Xiaomi redmi note
eddy2099sg
Hi sorry can direct me to the link? Cos can't really find the link after going to that website.
Thks
I think you need to reply to the link below the patch in order to see it.
First you need to login to the site using your mi credentials then just reply to the thread to get the link. I guess it's the post starter way of getting acknowledgement for his work.
Andrewtst
New Back Case for Redmi Note. :)
laironpark
Hi,
Thanks. Downloaded but may I know how to install the drivers?
My Device manager do not show any "Android devices" or even "other devices".
Thanks.
Ensure that usb debugging is enabled on your phone.
Then it plug into pc, which it should autodetect and attempt to install the driver.
(at the juncture, if pc fail to autodetect, change to another usb port)
When installation fails, go to Device Manager, and under Other Devices, it should show yellow triangle with exclamation mark for MTP and T8850. Right click on both, choose Update Driver Software, and browse to the location where you downloaded the folder and click to update.
After update, unplug and plug in again, go to Device Manager, and it should show HM Note 1W under portable devices.
juuzbe
you should update to latest firmware
so far I hadn't encounter any issue before
but the stupid camera-photo-save-to-memory-card issue still remains unsolved
hopefully solved in MIUI 6
someone posted a link to the Mi Forum whereby there is a patch for you to download and run in your phone. I had installed and solved the camera save to sd card issue. :s12:
oohman
You can try singtel shop. They sell note with their prepaid card at $215 (i think).
M1 and starhub may have it too.
Singtel must get plan.
So singtel sell $15 more than online.
What abt Courts, Harvey Norman or Mustafa ? I dun mind paying 15 more for an immediate set.
richneo
i just collected mine from saturday sales. much2x faster compare to f$ck up fedex
actually need to be fair to fedex.
fedex package was shipped each parcel by parcel from china to your house directly.
for the current one, xiaomi set up xiaomi distribution fulfillment centre where the stocks were already in singapore before singpost ship it out to you.
Andrewtst
After few days on using Redmi Note, here my short review
Pros:
  • MIUI ROM is just simply awesome with tones of themes. Can't wait on coming MIUI 6 which base on my favor Flat design.
  • As usual Stunning real camera! This 13MP is real deal where give you outstanding quality.
  • Front camera also suprisingly a great quality 5MP.
  • Outstanding HD IPS LCD, I find the color reproduction is much better actually, I prefer this IPS LCD than HTC One M8 - SLCD3. If the screen is FHD then it will be far than perfection.
  • High benchmark score in Antutu which no worried on it apps performance.
  • 2GB Internal on such RM 509 is just unbelievable. 2GB is minimum for Android to prevent any launcher restart issue. My friend Redmi 1s often facing launcher restart issue all due to 1GB Internal RAM issue.
  • Even though the speaker is only mono speaker, but I find it sound just nice, at least it still better than my previous Galaxy Note 3 and Xperia Z, Off course they is no way better than HTC One M8 Stereo speaker.
Cons:
  • Still under 4.2.2, hopefully soon can get 4.4.x since MTK already release source code base on KitKat.
  • Even though high score in Antutu, but they is no denied they is some smoothness issue, need some tweak to get good smooth performance. All in all I believe 4.4.x will make the overall smoothness much better in future.
  • Why Mi need separate the Themes for Global user, the themes inside is far lessor than China ROM. Don't talk on cannot buy the paid themes, even the free themes also little and like no updates. I had no choice did some dirty job for getting all the themes I want.
My Final Setup for getting much smooth performance:
  • Disable CPU power saving mode. (This mode auto on in every phone restart).
  • Windows animation scale - 1x
  • Transition animation scale - 0.5x
  • Animator duration scale - 0.5x
  • Root and install Mi-Tools (required WSM tools) and Disable scrolling cache.
galliano
Silly question, but my colleague in Shanghai now. He says his Note (SG) cannot detect the local SIM.
Is the 3G not compatible?
desert_moon
Yes,Fedex and UPS shipped from China.
Last sat sales stocks were at Singapore.
My popstation is ready for collection around 4plus today but my home delivery was delayed due " Delivery will be delayed due to high volume"
halocast
what network he using?
cannot use td-cdma one.
i think only China Unicom is the one compatible. :s12:
