Xiaomi redmi note
a1v1n_
You can go Daiso buy the $2 20mm sponge double sided tape (Black sponge in middle), I used it on my s3 clone and no-brand flip cover, and its very strong. I used a 4 cm length in the middle. Its also easy to peel off from phone back cover, but from soft plastic flip cover got to be careful, as it will tear off some of it.
will go take a look but will probably just sell off the flip case i guess.
if i knew the flip case was like that, i wouldn't have bought extra battery and just got a power bank instead. that way i won't need to constantly take the phone out. :(
Eternit
Hey guys I got this issue with the stock music player, music pauses intermittently about 5 - 15 secs, then after awhile will resume playing, sometimes also got static noise. The pauses occur without the earphone so I think it's the phone issue. Using latest MUI. Hope to get some advise thanks.
xeonboy
Been trying to find Redmi Note for the past few months....where can I get it fast other than xiaomishop.com? My current phone broke after it hit the ground a few days ago, need a good replacement fast.
Just Me
Get the 4g version lor.. now the 3g model I think you can only get 2nd hand if you dun want to pay chop carrot prices..
xeonboy
Thanks, but any shops here selling the 4g? The neighbourhood shops near my home don't have it.
motor750
redmi Note 3G
hi
I have the Note 3G
order date = 2-9-2014
collected @ SingPost =7-9-2014
Just got the Note 4G so you can have it
phone with battery comes with box - usb cable - user menu - receipt
condition 9.5 - Never drop - no scratches
screen protector since day one
$170
thanks
Cissiboy
audiohouse liang court has 1S and note 4g
not sure if local or export tho..i only saw them on display
UGeene
Hi, some input needed... Which is the most stable rom for our Redmi Note?
Is there any version where the GPS is fixed?
TIA
kangaroos_kang
Hi.
What software am I missing?
My notes 4g couldn't see picture or YouTube posted by forumers.
Even forumers picture below their nickname I also can't see.
It stated xoulndt load plug in.
I must click a small icon, then the picture will appear.
Pls help.
Merry Christmas to all.....
mingfreakrsx
Redmi Note 3G will get CN MIUI 6 with KitKat ROM on 13th January 2015!
Global ROM would be around that time too, to be confirmed.
source: About MIUI 6 for Redmi Phones and Mi Phones: New Timeline - MIUI General - Xiaomi MIUI Official Forum
Sent from GAGT Android App
yi_shiang
Thanks..
Anyway i just got my redmi note yesterday and noticed when typing using swiftkey, it cant keep up with my typing speed.. and the screen not very sensitive... normal? i literally i hae to type slower..
This is a known issue.. Whereby the screen will detect two seperate inputs as a slide .
xeonboy
Hi all,
Does anyone here feel that the Xiaomi Redmi Note uses up battery quite fast? Is there a way to prevent this? Last resort is to buy a portable powerbank.
zenify.me
Check if it's because of your installed app draining the batt.
xeonboy
Nah, I didn't really install much apps. It gets drained whenever I surf websites, even those that are not intensive. This is a common problem of smartphones right?
Also, a powerbank can store 2 - 3 times the amount of battery for the mobile phone?
mingfreakrsx
Xiaomi's 10400mAh powerbank is good, can consider. :)
