Xiaomi redmi note
mingfreakrsx
no OTA? no global ? sad :(
MIUI 6 Global should be coming very soon, maybe May or June 2015.
Hi people 1 question, I'm planning to buy the Redmi Note 4G on the Mi event which is happening in a few days time. I wanna ask if the phone is already running on MIUI V6. Is it official (OTA) or is it still in beta?
It should come with MIUI V5, but there's official Global MIUI 6 ROM available for OTA update for Note 4G.
Sent from my Mi device using GAGT
halocast
Why everyone ask for miui 6? Current miui got problem?
cause current note miui is based on jelly bean, which is like outdated and slower.
miui 6 is cleaner and nicer too :D
KK is definately faster and some apps works on KK and above only.
:s12:
cscs3
Any bros here experience problems with Posb android app on Xiaomi note as in the app will crash every time?
This has been a known issue with Redmi 1. Though it should have already been fixed?
halocast
iirc note 4g got official global miui 6 . can just update if yr phone comes with 5? :s12:
KYLee
i went ahead and use the guide to flash the miui v6 on my redmi note but after flashing, my google play or rather all google services stopped working. any help?
cscs3
I think you flash to China version? CN version has no Google play and etc.
KYLee
yup i did, i uninstalled google play and reinstalled but it didnt work as well.. so that means china rom cannot have any play store at all? i installed Gapps manager also cannot.. infact, even the mi store is not working.
jackasshole3
This mi note is starting to get annoying.. After using it for 11months...internal 8gb actual around 6gb to install. When left less then 2gb,phone will slow down like ****. Good point is only the battery. Keyboard are delay when typing. I clear all cache and junk but still slow and sluggish... But anyway. China product and lasted close to One year, that's more then good already I guess
mingfreakrsx
Likely to be the Redmi Note 2 specs, comes with 2GB RAM. :)
geckoSG
tats why I skipped n bought meizu m1 note instead. 3 cons to me is only 1x 4G slot, no external microsd, no AC, but dual band N wireless.
epos
Anyone bought the Power Adapter Bundle with Mi Power Bank 10400 mAh? like to know if the power adapter output current. if its 2A then the bundle is very worth it, 1A then not so much.
