Xiaomi redmi note
Frederick84
anyone using redmi note 3G to play tsum tsum ??
how to fix the crash when agree on the line login ar ???
geckoSG
Dun Need to wait for V6... By the time your warranty finish liao it might not even come out
mun
Found someone posted the below in the reviews, not sure if it helps, but you can try :)
'ANDROID 5.O USERS Found a work around to the black screen crash when authorizing line! This worked for me the first time so hopefully it'll work for you: Go to your LINE App. Settings>Notifications>Authorized Apps. Delete Tsum Tsum Authorization. Now you should be able to authorize in the Tsum Tsum app. Good luck! Other than this glaring bug, it's my favorite mobile game. Addicted for sure.'
Frederick84
thx for the help..
i go authorized app there look see.. no apps inside to be authorise at all lol..
still cant play..
kweeli
Anyone experience after full charge, the phone will stop charging and battery lvl drop gratually.
By tye time unplug, the battery lvl already droped to 80 or 70%....
xeonboy
Is it impossible to update my xiaomi redmi note 3G to at least android 4.3? It's 4.2 currently.
cscs3
Global version no news yet. They are still busy with very late promissed upgrade to KK for other model wgen most other brands has move to LP version 5.
DonaldGoh
I updated my Redmi with China v6 Rom via the phone update and install Google apk Playstore and now my Redmi is working with MiFit doogle and has google playstore. However, install at your own risk. Now every Friday, there is an auto update.
kweeli
Can anyone explain why they need long time to release global rom since they already release china rom and is working fine?
amazingone
yup, the CN Developer ROM has weekly updates that pushes new fixes and/or new features regularly. :)
Sent from Samsung GALAXY S6 using GAGT
cscs3
First they wait for cn version to release. Then they modify from there. As it took a while, so even bugs already discovered in cn version is also repeated in global version. Very poor development process.
