Xiaomi redmi note
Alexz_Hong
Have backlight. Right now I see my phone which is locked, the 3 buttons are quite visible actually even without light.
Have, but it says not compatible with this version.
Don't have a redmi note, but the app says it requires 4.3. Redmi Note is 4.2.2 sadly
Description
This app requires a Misfit Shine and an Android device with BLE (Bluetooth Low Energy). Get your Shine at www.misfitwearables.com/shine
Shine is the elegant activity tracker that inspires you to live an active life. Wear Shine anywhere on your body with our range of upgrades that are designed for comfort and style. Shine’s long-lasting battery and automatic wireless syncing mean you’ll spend less time plugging in and more time moving. Use the Shine app to access these features:
- My Shine: Create a goal and Shine will give you credit for running, cycling, swimming and more
- Activity Progress: Check your activity progress and see stats like steps, calories and distance
- Sleep: Find out how much sleep you’re getting, including deep sleep.
Supported Devices:
Samsung Galaxy S4, Samsung Galaxy Note III, Google Nexus 4/5, HTC One and other Android device running OS 4.3 (Jelly Bean) with BLE enabled."
ahtai_7
Thanks for the assistance :)
Hope this info will be useful for others too!
oops I just saw your message.
the redmi note is in my office drawer.
been testing the Find 7A/7 over the weekend for review.
will try to get back to you on this b4 lunch tomorrow.
kopi22
this is a piece of outdated phone ... why ->
1. 720 pixel on 5.5 inch is :o, 267ppi
2. 3200maH battery for 1.7Ghz octacore :o, 0.5 day use after 1 year
3. Arm A7 octacore :o, A7 core is used for power savings mode, having 8x A7 core 100% confirm sluggish
4. Use MIUI rom to mask the sluggishness of A7 core :o
5. 200g weight :o
6. Glossy plastic back casing, 1week in wallet with key chain sure scratches all over.
7. download at 4Mbit/s -3G speed :o, what is cat 4 LTE used for when stinktel already rollout cat6 LTE -300Mbit/s full by end 2014. stream all those blurry youtube stuff, choose those HD content, play for 2sec, download 5sec repeat.
8. $199 - Yes cheap, only problem is $199 throw into dustbin, since outdated product, rather spend $300 for updated products, once bought zero resale value.
no need rush buy note, every china manufacturer selling more or less same, TCL is alcatel french subsidary incorporate in china. For 1000RMB ~200sgd already out since May2014
TCL S725T, 5.5-inch Android phone with octa-core chipset
I don't care. Will still be getting. I will let you know if RM Note is as bad as you said after using it. I'm not going to watch youtube on my 2GB data plan anyways.
Lexyyy
I will still try though haha. What do you guys think of it vs my current iphone5(no s). Aside from the the lower ppi and lack of LTE.
SpeedWeed
iphone 5 is way more expensive than xiaomi note leh
:s22::s22:
iphone has a built in environment. are you sure u can give up the existing apps u got etc?
SpeedWeed
its a decent spare phone and travel fone
dual sim ftw :D
Lexyyy
:s22::s22:
No more carrot head ma haha. Just a basic user dont really need an expensive phone furthermore, i see the redmi note's specs quite comparable. I usually watch preloaded videos, whatsapp, surf social media and most importantly EDMW!
