Xiaomi redmi note
Alexz_Hong
Then Philippines, Shenzhen, and then Singapore...:D
not a joke. lol.
laucm
It's coming...... Tomorrow!!!!
UPS changed the Scheduled delivery from 16 Jul to 11 July :s12:
Maybe flying straight to changi airport after Taiwan
bbcccc
mine too changed from 16/07 to 11/07
its in taiwan taoyuan now though
dunno will reach me tml bo
i've been using the xiaomi NOTE for the past couple of days, everything was great but it as only been running on EDGE instead of 3G.... can anyone shed some lights??
Nakedtoes
Dun be happy yet.. That time mine mi3 also change date to earlier date.. Then on that day morning reached Singapore but delivery 3 days later. Those using ups one dun be happy yet
hyper_megaman
did you buy from the digital expo or somewhere else?
u got the china version that only supports 2G isit
the export versions are labelled "WCDMA/GSM" instead of "GSM" only
the "GSM" ones are intended for china use only
whoooo
Either u bought the China model which only the 2g can be used or u slot ur 3g card into the 2g slot
halocast
either wrong slot for yr sim card, if not u are using china version?
or maybe some setting u change ? :s11:
halocast
hope this time is better :s12:
hyper_megaman
walau eh... mine is still far away
what happened sia... discovered insufficient units?
i guess my dad got scammed.. we bought it in china for me.. the specs on the box said
"支持中国移动3G网络(TD-SCDMA)"
"支持中国移动,中国连通2G网络(GSM)"
xiaobai1
Not really scam since you bought an export set and not local so can't blame the spec and did you ask?
halocast
wha.. td-scdma.. thats the china version.. cannot use 3g in sg :(
halocast
well, i guess my father not that tech savvy, probably tt person who sells the phone to my father not being honest and truthful.
well if u buy in china, they probably could've thought u are using in china? :(
unless yr father did ask beforehand? :s11:
smallspider
departed taiwan. most likely same as the screenshot by a bro .
going to philippines and china tonight then arrive sin tml morning. if no screw up, lucky ones should get delivery tml
