Xiaomi redmi note
gerraysii
Anyone has any issue with the color processing for image while taking pictures? When I take pictures for my note, it seems like blue color item seems abit greenish while green item seems bluish purple. Any idea?
HUGO15481
Anyone has any links to go about rooting Redmi Note?
Want to read up before the device arrive and can root it so that I can transfer the apps to sdcard.
whoooo
Here ......
en.miui.com/forum.php?mod=viewthread&tid=26572&extra=page%3D1&mobile=2
napster79
anyone knows how to set MX player as the default video player? I cannot find any option for that.. :s11:
Alexz_Hong
Try going into settings, then under apps. when you go in it'll show you your downloaded apps etc. The bottom bar has a button called "default app settings" or something like that. try there?
Alexz_Hong
how do u all access the normal video player?
if you have videos on the phone it will show up in gallery app, or your file explorer. When you tap it opens the default videos app, but it isn't in the app list. BTW the default player's control is like VLC beta, which is rather nice. Lol.
If you using the Chinese version, the video app will be an icon since can use the app to watch videos from like sohu. Pity not available in SG version.
halocast
yeah was wondering where the icon was, thanks!
halocast
its not highlighted.. cannot do anything :s11:
Alexz_Hong
you mean the "default app settings" button or the section to change for "Video"? If is the latter, even after installing another video player still cannot select? I don't have another video player installed so not sure how it works. lol.
halocast
default app settings button, don't seem to have video player selection.
weird :s22:
chenaz
How do we turn off button feedback?
there are 2 settings . first one is the guy below mentioned.
another one is
if u are using google keyboard. then go to ur input setting and click on ">" at google input and turn on the vibrate
