Xiaomi redmi note
Alexz_Hong
Anyone knows if toa payoh or amk sells tempered glass screen protector ? Cos nearer my place lol
The second link I sent. Amk. If you drop by his place he can help apply too. I've been using his glass screen protectors for my iPhones, all good quality.
ManUnited7
Seems that the case needs to have a chip embedded on it ,I think qoo10 sells them .Not sure how well it works as I heard the app not 100% working with note nor with other phones as in the reviews hence not really reliable.
I bought the double opening ones in taobao which seems like a new trend ?At least not program dependent and 100% works .
How to change function of Home button of note? I dun want the lousy iphone home but the android one which select recent opened apps.
Thanks for your reply!
Can you show me an example of double opening case? Don't really get it.
yhw22
Anyone got problem with using 3rd party charger when charging. Found that only occur when using non-Xiaomi charger or powerbank. During charging, the notification light will light it, but notification bar the battery animation no show and % of battery at Lock screen. Anyone facing this problem???
eddy2099sg
Anyone got problem with using 3rd party charger when charging. Found that only occur when using non-Xiaomi charger or powerbank. During charging, the notification light will light it, but task bar the battery animation no show and % of battery at Lock screen. Anyone facing this problem???
I'm using an iPad charger with my redmi note and so far no problem. Are you using the provided cable ?
yhw22
Tried using xiaomi provided cable also no charging animation at notification bar and lock screen, but got notification lighting.
eddy2099sg
Tried using xiaomi provided cable also no charging animation at task bar and lock screen, but got notification lighting.
I guess if it is actually charging your phone, it might just be a minor issue.
yhw22
Probably can't exchange the phone cos it is working with the supplied charger.
It also got non controllable with homepage moving by itself without touching. Only after restart then back to normal. And after completed charging, at the Notification bar left hand got circle kept spinning. Restart it then disappear.
doggybark2
Anyone interested to get a set?
I ordered and received it but realized I can recontract and got another phone instead
So I now have a redmi note bnib with me now, any bros here want?
Only open to check content, haven't even put battery in
I will let go at $200
But must collect at paya lebar at my timing
djzilch
Is there any actual smart cover for redmi note thats working? Just curious if it has the magnetic sensor or not
timpeh82
After finding the good quality screen protector, anyone knows where to find good smart cover for redmi note?
micheloving
hyper_megaman
no such problem for me
micheloving
