ZTE Axon 7
cyrilng
Looks like A2017 exclusive. Don't like the Mi pop tho
What's your software version?
I use it all the time though it gets in the way sometimes but it can be moved to any part of the screen.
Still on B07.
cyrilng
I don't have Mi- Assistant on my US set as well. How do u get the download speed on the status bar? Build in or 3rd party?
It's under Display Settings. Can set to show battery percentage and network rate.
sparhawk699
Er, how? I only saw Default to be either home or back key. There's a separate screen lock button though.
You can customise your Mi-pop, mine I customise 1) backward 2) lock 3) home 4) clear and 5 screen capture, on all 5 slots
cyrilng
Ah ok, press and hold then the options for Lock screen, power off, etc comes on. :)
siewmai or hargow
Just checked on Google play. Mi assistant is a app but is not available in Singapore
Sent from A Bottle Of Knee Gel using GAGT
