ZTE Axon 7
cyrilng
No word on availability and pricing though.
https://news.samsung.com/global/samsung-introduces-worlds-first-universal-flash-storage-ufs-removable-memory-card-line-up-offering-up-to-256-gigabyte-gb-capacity
It will be compatible with some phones only.
cyrilng
Can anyone tell me how to configure the settings so that the icons on the top bar on the desktop will be in white on dark background wallpapers?
stylechap
Hi, anyone got their set from china here?
I'd like to know if google playstore can be installed or found in their 'ZTE-Market' which some people refer as.
siewmai or hargow
Tried hard reset twice already.
Came with PlayStore app but when I first clicked on it, it wouldn't work. Then tried installing my gmail account and it prompted me to enable Google Play Services which was not in the app list originally but it only showed up when I tapped on 'Enable Google Play Services'. After that, it just goes get stuck on 'Checking Info".... :(
Tried downloading and installing the Playstore apk as well but still to go.
Dk leh. His one has playstore insai when he bought it
Sent from A Bottle Of Knee Gel using GAGT
cyrilng
Yes, mine came with playstore pre-installed already but you can also download and install the apk but you must set play store to be allowed to auto run in the Mi assistant.
stylechap
Thanks for your information :)
It's less than $450 with shipping from taobao/tmall. Compared to local pricing,savings is too attractive :D
cyrilng
Yes, I bought mine which is 4gb/128gb grey model for $500+ (with no gst) from Ali Express.
cyrilng
If it is a part which can be removed I still can do it myself.
But not loose soldering or soldered parts that makes the phone go haywire like nexus 5x that I've read lol
Well here's a link to the tear down video and a surprise finding too.
https://community.zteusa.com/thread/13026
stylechap
Thanks. Haha so they over stated the capacity. But for such calibre and ~150mah, it doesn't really bother me much though.
What bothers me is theres different ROM and model for different market. This puts me in a dilemma.
The Nubia z11 seems to be able to flash ROM interchangeably but cost higher with lower specs.
stylechap
I though Nubia z11 difference is the resolution, glass and battery? I actually wanted the z11 but it isn't available here
Yes it's only full HD compared to 2k. Not sure about battery.
Glass iirc is gorilla glass 3 to glass 4 on axon 7.
Axon 7 have LTE-A while z11 is LTE only.
With all these lower specs,it cost rmb200 more in tmall just for better outlook haha.
So I have to choose to pay more for lousier spec with international ROM compatible or pay less with better performance but may have problem with playstore.
cyrilng
Saw the Nubia Z11 but decided to go for the Axon 7 instead as it has an Amoled screen and dual stereo speakers as well. And Z11 has a 3000mAh battery only.
http://m.gsmarena.com/zte_nubia_z11-8091.php
