ZTE Axon 7
Anything_Whatever
Can install the update while on Nova Launcher or should I switch back to stock launcher before the update?
Better to switch to stock rom before updating to nougat.
Reason is that it appears there is a Launcher3 in the B02 with the drawer for apps, besides the MiFavor 4.2
cay_one
maleman
Woo hoo, managed to upgrade to the latest version
Sent from ZTE A2017G using GAGT
Anything_Whatever
Before I updated to Nougat, when I tap to Silent, everything is silenced, even when I watch YouTube. With Nougat update, I've to adjust volume to zero instead.
Press and hold on the "Silent mode" icon.... the SOUND setting page will appear.
Slide the media and alarm to the left.... then press home button to exit.
That's it, it should work.
siewmai or hargow
cyrilng
Sianzz
Can anyone recommend a place/shop where moi can get tempered glass n case? Need one person help me apply tempered glass *********
Sent from Meow Meow Meow using GAGT
All the tempered glass protectors won't fit the full screen and the edges will also not stick down well from all the reviews I've read. I managed to get a normal clear screen protector locally but it was the last piece they had. http://list.qoo10.sg/item/ZTE-ZTE-A...NO-PROTECTION-FILM/492990828?selectedOptions=
What kind of case are you looking for?
siewmai or hargow
