[Maylyn - Networking] ASUS RT-AC88U
ravener
Im on Starhub 1Gbps, the wifi doesnt cut off per se, but my internet access just kinda stops after using a while.
I've got both the 2.4Ghz and 5Ghz network on, so when i stop getting internet on one, i just connect to the other network and its all fine again.
Sent from hamster factory using GAGT
Gixxerfied
So recommended not to updated the firmware??
I just sign up a new fibre line with m1 for new house and purchase the ac88u at $339..
kuronie
Highly recommend not to, if the thing is not spoilt, don't meddle with it :)
Jun Jun
You can update to 2345 from asus website. just unzip the package and upload the firmware to your router thru the firmware upgrade. Do not use the auto update as it will update to the latest 3341, which many of us is bugged, and cannot be flashed back. So far 2345 is quite stable for my usuage.
Gixxerfied
Noted..
Will rem to do so once i open sesame the package probably in 3 weeks time..
Khairilasny
On stinktel, probably their issue.
Yup, probably their issue alrite...
Anyways, just 1 to 1 exchange at Avertek this morning and just hooked up with firmware 2345. No drop issues so far. Avertek guy also mentioned that 3341 firmware is not so stable for some users with same intermittent drop issues.
Jun Jun
Precisely, and also do a factory reset aftet the update ya guys. For my unit I would just let it be since nobody complains about wifi for a week now:)
Khairilasny
So far so good now for me on 2.4G, but on 5G, there is once a drop of wifi connectivity for the phones.
localITguy
Suspended
I JUST lost my 2.4 wifi on the latest fw ( M1 1Gbps)
i have managed to use asus recovery to restore to Firmware version 3.0.0.4.380.2345 ( will monitor)
DO NOT UPDATE YOUR FW For now new AC88U Users!
Jun Jun
Btw, what version are you running when you lost your 2.4ghz connection?
localITguy
Suspended
i think my phone might be faulty ( 2.4Ghz stopped connecting. only 5Ghz work
all other devices able to connect to 2.4Ghz )
it was the latest version
rolled back to 2345
anyway users should avoid new fw until issues has been fixed by asus
Jun Jun
rolled back to 2345
But the latest version, 3341 is unable to rolled back to any version??? Correct me if I am wrong, it can be verfied by checking on your router page, at the top of the page where it states your current firmware version.
evildoctor
The latest firmware does not really give me much problem. I think sometime, is heng or sway. But definitely, asus has to improve on the firmware's stability.
kelton
i was able to downgrade using rescue mode method
read carefully before proceeding
https://www.asus.com/support/faq/1000814/
hope this helps
