Hi, I am looking for BN44-00428B; SAMSUNG Power Board for 55D7000, OR anyone advice TV repair shop in Singapore, who repair board on component level, since this board is working but due to Capacitor issue , power dropping again n again.. Please suggest repair shop, tried couple but all wants to replace the Board with labour, which is quite expensive (approx $400).
I'll know when the repair man come tmr morn..the model abt 5 yrs old maybe eol but spares shld be available as some models share same internals except for screen size..will know soon enough
Please Help.. Need Motherboard/Main Board for above TV... Please PM me if available!!!
Thanks
Thanks.. The problem is that the TV was purchased in Thailand and was being used in India. Philips India says they do not have a replacement motherboard since this model was not being sold in India. So I guess the only option is to buy a replacement Motherboard from Singapore. Please advise
No where to get as manufacturer control the part. Since your Tv is more than 5 years it is quite old, it will be better to get a new 49 or 55" UH650T which has HDR and colorprime etc. It is good and cheap. If you like 3D then go for 49UH850T.Having some remote issues on my 5 yrs old LG LW6500 47 inches LED TV.
Handheld remote doesn't seems to syn w TV. Exp: When I press A it will appear B
Spoken to LG service center was told the remote sensor in the TV most likely gone.
Total cost including labour and parts about $330.
Any LG user has the same issues before and anywhere else I can get a cheaper repair deal?
TIA
TIA
Thanks for the heads up, new problem surface today. Now the power white light is blinking but tv still able to watch.No where to get as manufacturer control the part. Since your Tv is more than 5 years it is quite old, it will be better to get a new 49 or 55" UH650T which has HDR and colorprime etc. It is good and cheap. If you like 3D then go for 49UH850T.
This is my 1st LG and to pay $2500 for 5 years seems a little too quick to end its life span![]()
Nowadays a Tv only last 50,000 hours max and many brand like Samsung will go up lorry after the warranty just expired. Can last 5 yrs is already a bonus. You can repair or get a new Tv. No choice.Thanks for the heads up, new problem surface today. Now the power white light is blinking but tv still able to watch.
You can try ubi ave1 blk 302
