Head/earphones Recommendations Thread
eyz
thanks bro. i'll stay with it for the time being, though i'm eyeing the audio technic m40x.
Sibera V2 actually not bad sounding I would say.
Good enough for daily use.
Anyway mine is the Diablo limited edition. USB type.
It does have those vibration/impact but sometimes over limit of the driver can take if you on too loud that's like almost at max.
I still using it daily for my pc. Like watch youtube, shows all those, music not bad also IMO.
Decent all rounder.
eyz
not yet bro. i'm a noob, trying to get a budget headphones for movie watching.
read review online and the sony mdr7506 was highly recommended. but jason commented about the frequency, which i really don't know what is it about. but i trust the guys here.
i saw a video on the comparison on mdr7506, ath m40x and hd280, and found that m40x gave the most accurate audio as compared to the source.
i'm looking at wired only, as it's cheaper and lighter.
Have you tested M40X? the reviews seem good, i am considering this and the sony wireless headphone.
Jason8811
Actually don't trust the people here so much, we are only able to provide recommendation based on some of our personal experience. As far as audio and sound is concern, it is very personal and subjective so the ONLY way to really know what works is to test them yourself. Reviews are great, your ears are more accurate. ;)
idrinkecoke
I tried a few headphones today but being someone who wears a specs, most headphones make me feel uncomfortable.
Anyone with similar experience?
Jason8811
Yes this is normal, remembered I used to have such issue myself before Lasik.
You could either consider getting an "on ear" headphone or even better, choose an "over ear" headphone with very soft padding. Of cos I believe most people train themselves to be immune to the pain after a while....:s13:
acess 1
thanks guys!
do you have any recommendation of headphones for movie watching, which is below the price $100? i know it's a little low, but wanna try a entry level headphone first.
or should i stick wifh my steelseries sibera v2?
someone recommended me Sony MDR-XB450AP as well and it's quite affordable as well.
Can consider the X- mini evolve . Carousel selling BNIB mostly below 100 .
Tons of features . Interesting head set / products x mini portable speakers by one of our very own local company .
Product specification description below link .
http://www.x-mini.com/product/x-mini-evolve-wireless-headphone-speaker
huei92
- Your rig : Android phone (OnePlus One), laptop
- What type of usage : Music & Movie
- File format used in your source: mp3, m4a, flac
- Genre of music you listen to : classic, kpop (prefer lesser bass)
- Headphone/ earphone type : IEM only
- Other requirements: mic & volume control (android compatible)
- Budget: $100-150 (can top up a bit)
So far i know there are a few that might suit be but i would like to hear some recommendation/ review and they are:
ATH-CKM500is
ATH-IM50 / IM70
TFZ S3/ S5
Shure SE215
Senheiser Momentum In-Ear
Marshall mode eq
volume control and mic are optional tho, it would be great to have it
WillRock
help me also!
- Your rig : Iphone 6 plus
- What type of usage : music, phone call
- Genre of music you listen to : classic, pop (prefer lesser bass)
- Headphone/ earphone type : in ear
and anybody use dubliz fischer before? good?
Jason8811
ATH-CKM500is
ATH-IM50 / IM70
TFZ S3/ S5
Shure SE215
Marshall mode eq
Most of your options seem to be warmer and slightly bassy to me but maybe you have auditon and felt those are fine. Given your choice of IEM to have less bass I might go with the RHA 750i. http://www.stereo.com.sg/rha-ma750i.htmlFantastic built for the price and excellent accessories provided.
Jason8811
Same as previous recommendation RHA750i
Reapple
- Your rig : iPhone 6S, PC
- File format used in your source: MP3, ALAC
- Genre of music you listen: Pop rock, rock
- Other requirements: Similar sound to IM02
- Budget: $300-500
idrinkecoke
Can i say that neutral headphones are not good for movies?
Is it consider expensive for headphone to cost 250?
Jason8811
Considering that there are headphone over $6k, no.... =:p
Neutral sounding is subjective so its hard to say what is and what's not, this is quite personal. However in general "neutral" sounding aka balanced sounding headphone should work for movies but varies to what movie you are referring to. For dialogue to be clear then the mid range of the headphone should be transparent enough to achieve that but for action movies you probably want a bit for bass and a wide soundstage for the effects.
Jason8811
- Budget: $300-500
Audio Technica IM03? Otherwise the new Etymotic Research ER4 range are suppose to be quite similarly good too.
Teo Ming Ern
Anyone knows where to get a pair of Marshall Major II Bluetooth headphones and how much they cost? What's the sound quality like?
Nauxil
First time buying headphones
- Your rig :Note 5, PC
- What type of usage : Music,TV Shows, Gaming
- File format used in your source: MP3, MP4, MKV, FLAC
- Genre of music you listen: Pop, rock, indie
- Headphone/ earphone type : Over the ear closed headphones
- Other requirements: Simple design, nothing complicated
- Budget: Under $100 (Can stretch to $120)
Was told to buy SkullCandy's Hesh 2 but seller sent wrong item and now out of stock so looking for other options. A bit tight on money so budget is pretty low. Need one urgently due to new roommate so thanks for the recommendations in advance.
Jason8811
The audio technica m40x should be most value of money. http://www.stereo.com.sg/audio-technica-ath-m40x.html
