[RIP] Samsung Galaxy Note7 Thread: Share ur last thoughts
Bonn
Those steel teeth die also don't want to return their Note7, be prepared to face your own consequences. Risking your life of your own, family, and those people around you.
All never kena can just talk only, when really explode i laugh at you. 铁齿是没有好下场的, 不听老人言吃亏在眼前。
Samsung Galaxy Note 7 to be cut off from all New Zealand carriers starting November 18th
http://www.phonearena.com/news/Sams...aland-carriers-starting-November-18th_id87416
Hope a global cut off to be implement soon so i can laugh at those keeping a potiential worthless explosive brick.You better don't come near me or invite people sit close to you. Well i cannot blame them as some people aren't very bright. Yes, you love the phone but is it worth the risk? Common sense key here.
Common sense is never common in the first place. If the phone really have that self combusting issues (argue to death topic for the past 1 month), it would have occurred all over the world for the past 1 month. Most have brains have they can see that most of the cases are in US. Not sure what the hell the Americans are doing with their Note 7. Maybe sent it to Mars and back and etc which caused it to self combust. Jokes aside, looking at the statistics, its just not convincing enough to discourage hardcore Note users to stop using it.
Fellowes
No worry, you continue using the banned phone. Its all right since its your phone but Samsung made the final call here. You all continue to justify and argue your rights with survey, stats... blah blah then, you all in the end LLST if global cut off. :look:
I myself already treat Note7 as something i didn't hear or see before. No such product exist. Factory reset, turn off waiting for delivery guy to come and take away the potiential explosive phone from me. Case close and move on!
renfred89
It is the uncertainty which cannot be predicted made samsung encourage users to stop using it for your own safety. if you choose to turn a blind ear to it, then you gotta take the responsibility in your stride should something happen to your unit.
you yourself should know that statistics does not compute risk. there is no way you can measure risk, you can only predict.
BraveCloudy
If Samsung Singapore really implements cut off from Singapore carriers, I also don't care much. They already released Note7, whether they recall or kill the device, Note7 is still in my mine. Unless they releases another Note7 next year which I doubt so, I can forget the current Note7.
Otherwise, its a NO.
No matter what, I will NOT return.
Money can always earned back, once Note7 is returned, its gone, forever.
crntbs
Think the issue is not about how many phones have exploded or where it has exploded.
The issue is samsung was not able to find the root cause of the exploding phones. Common sense tells me that samsung would have checked how these ppl are using the phone and whether the explosion are real issue.
Guess there are some behind the scene stuffs which warrant samsung to bite the bullet and recall all n7 phones.
ckjoe234
agreed... while myself predicted tat chances of my n7 kaboom is base on stat, which is very very low but theres still a small % tat it might kaboom, tat i dun deny..
yest nite kena the auto/forced update also..which seems to me tat samsung is fully capable of even to the extend, thru an backend update to completely render the n7 useless. the 60% batt cap is just the appetizer..main course haven come..
good luck to those intend to keep the n7 for usage, goin the root method might seems to be the only choice for now but dun forget...to root ur phone = opening all backend doors as well...if u get what i meant...
marigoldhl
Go ahead and keep your Note 7 that will soon become a brick (if IMDA ultimately decides to block Note 7 IMEIs from all Singapore SIM cards), has absolutely zero value, no warranty, no update or whatsoever
And please do not go around this forum and claim that your Note 7 is a 100% safe set when Samsung has said so clearly that no Note 7 is safe - in this case if your phone suddenly burst into flames somehow after the exchange period (one in a million chance) then please claim your Darwin Award by all means
FYI there will be a Note 8 in 2017
LiLAsN
The latest version of Package Disabler Pro has already hid these processes from being disabled, most likely requested by Samsung. From Google Play store: https://play.google.com/store/apps/details?id=com.ospolice.packagedisablerpro&hl=en
"WHAT'S NEW
Following packages won't be seen in the list ;(
- com.wssyncmldm
- com.sec.android.fotaclient
- com.ws.dm
- com.samsung.sdm
- com.sec.android.soagent"
Don't waste your money to buy the app. The only way now to prevent the battery update is to restore the firmware using Smart Switch and root the device.
Refer to my Post-Firmware Downgrade guide.
Basically, you'll have to enter the packages manually. Then after a while you'll see it in the list as well. Just takes time for the app to find all hidden processes.
Wow. Luckily I didn't get it.
POST-FIRMWARE DOWNGRADE
14a) I am using 'Package Disabler Pro (Samsung)' that you can find on Google Play. (Do remember to give the app Admin access when requested)
14b) Then on the app, click the top right hand side and choose 'Manual Disabler'
14c) Then type in, 'com.wssyncmldm' and then click 'Disable'
You no longer have to fear the Software Update. Just use Wi-fi as per normal and you will still have no issue like me until now.
(Note the app costs $1.48)
15) Also, for Smart Switch, click on 'More' -> click on 'Preferences' -> click on 'Software Update' and untick everything in it.
Until now, still no update. I always put a backup plan in case Plan A fails.
I thought it wasn't really that important since we will be changing phones very soon. Nonetheless, my apologies for not including the post-firmware downgrade guide. The 'Package Disabler Pro (Samsung)'costs $1.48.
LiLAsN
No my dear, we must reserve a date for them to come over and exchange our phones. And if you are late to book, the reserved date can take up to the end of November. So we don't really have a choice other than to live with the 60% for weeks.
Before spouting nonsense, if you do not know how a lithium battery works, I suggest you don't spread false threats around here. There are no large explosive elements in the phone or we would have to surrender the phone immediately.
The battery starts to get fat and the elements inside starts to leak like how we see with our previous phones when they are overcharged for too long. If it comes into contact with other elements, it might catch fire and will burn through the phone.
However, total reports of this happening is still less than 100. If you actually bothered to calculate, that is 100 divided by 2.2 million users times 100% giving you 0.000045% chance of it happening to you. The risk is so slim that not even Singapore has a report of it happening for the total of 3 months since the device launch.
-Avenged-
Don't bother explaining it to people who have been infected by paranoia and mass hysteria. They put on blinkers when they speak, not realizing that millions of other products in the world use Li-Ion batteries too. To them, only Samsung has this revolutionary new battery that's suddenly combusting in the millions, so the Note 7 is evil while everything else is a saint.
I have said before in earlier posts that:
1. The incident rate is actually, statistically, still extremely low when you compare it to the number of phones sold and used (which you've mentioned).
2. Many other phones by other manufacturers have also caught fire (I even gave links and examples).
3. We don't really have much clue how those who have seen their phones combust, have actually used their phones before it went up in flames.
I conceded that, yes, the battery design is probably flawed to a certain extent, but you also do have to note (lol) that Samsung has actively tried to replicate the problem in their labs and they cannot do so. This suggests that the flawed design itself is a contributing factor, but that there are variable catalysts out there that trigger the combustion.
So yes, return your phones and get your refunds, because Samsung is being a bit of a dick about the whole thing too by forcing the 60% update on everyone so quickly. But FFS, go get some common sense before making apocalyptic prophecies.
And really, if you're really so afraid of the Note 7, then I suggest you go back to using nothing more than corded home phones (because yes, even cordless home phones use *gasp* Li-Ion batteries!).
muddle
There was an incident probably two weeks ago in Singapore.
It was initially posted on Samsung Mobile's SG fb and was taken down an hour later. Perhaps there are more but swiftly silenced by Samsung.
kelvinti
Don't be a stubborn ass! Don't be a hero. Don't be a fame seeker here.
Shutdown your N7 asap and go get a S7/S7e or Note 5 asap.
WhiteHunter
They will prioritse exchange programme 1st.. im planning to change my blue to rose gold cus no case suit for blue
sure will have cases for blue colour. by now they should have allocated stocks for exchange programme.
elriclee
yes. everyone have right to make their choice about keep or refund. i myself choose to get a full refund as this matter getting blown out of proportion but seriously note 7 is a darn good phone and i have choose to keep using it till i return it on nov 27.
i accepted that there is a very very slim chance it might get hot and burn up but it will most definitely not explode and endanger myself or others. like what others have stated. so many other phones have burn up as well, if we are that worried then might as well don't use any device with battery. anyway lets hope note 8 comes soon. ^^
