The Hair Thread - Part 4
gaoxing84
strands falling down.
For MM, is it advisable to use hair spray?
Means your few strands is not long enough.
Very normal. I would suggest against hair spray.
Looks damn unnatural.
Defeat the purpose of restyling ability of the product
shsh91
okay i will monitor.
i used around 10c coin size of the wax, felt that it was not enough, so use another round.
super365
Can uevo grey be used with morris motley treatment balm? If yes, how to use both together?
What are the differences of MM vs uevo grey?
Is MM greater holding power than uevo grey?
Is MM harder to wash off?
SaltyLeaves
I dont have uevo grey but having used mm for a month it comes off very easily with shampoo.
xiasuaykia
You will never go wrong with MM. 1 bottle lasted me almost 4 months. Definitely worth every penny of it.
gaoxing84
uevo grey is lighter, fixated hold
mm is restylable and slightly thickens your hair, overall stronger.
i don't recommend using together.
both are easy to wash
sansanjikikut
Morris motley is entering wholesale for Asia. So for those who always wanted to try but on budget, rejoice soon. Pray price will drop to 35-40 ish, affordable enough to buy 1 tub every 2- 3 months. Source: their insta
gaoxing84
i think price will remain at 40-45, they're already retailing at 40AUD on their site, i doubt it will be any cheaper than this in Asia or Singapore.
wait for my good news, i hope.
:D
super365
What are the differences of:
1. Morris Motley Treatment Styling Balm
2. Morris Motley Chrome (Shine Finish)
What "treatment" properties does Morris Motley Treatment Styling Balm have?
super365
Uevo Grey
After opening does the products still expire according to the expire date printed?
After opening, how long can the product last (become bad, cannot use anymore) from opening date?
super365
Does Morris Motley Treatment Styling Balm makes hair look shiner (oilier) than Uevo grey?
Uevo grey more matte look?
gaoxing84
Uevo Grey
most are 2 years shelf life in kept in dark cool area if unopened.
and you won't be not using it for 2 years.
helps to treat your scalp, thickens hair.
difference is the finishing, as stated
both are matte
