Xiaomi Mi Max - Part 2
allanzzz
It's Android Nougat 7.0
Lil_d3viLz
Guys, Mi Max slipped off hands and ended up corner of screen is utterly shattered.
What is the cost of screen replacement?
Phone still functioning as normal.
Nnb repair shop quote me $150. Gotta be kidding me. I rather get a new one.
i1magic
yeah I did so many things just to have, 10 more hours SOT, 36more hours of standby.
after the hassles, I used the phone as normal.
its hassle only when I manually backup files which is like once every few weeks, and updating of apps, only banking apps require latest version.
but that's me lah, perhaps only the weird one doing it.
LOL! Basically, by doing all this, you feel happy about it right? Then ok liao.
Whatever we do, as long as we are shiok about it, happy about it, can liao.
i1magic
1982-1994
Agree. If need to turn off this, disable that, cannot use this, install minimum apps, then can enjoy 2hrs or even 5hrs or even 10hrs more battery, then I will just get a powerbank and use the phone normally. LOL!
who mentioned about turn off this,disable that, install minimum apps? nonsense.
powerbank is just rubbish that adds on your burden.
1982-1994
Not just Google. Facebook (Whatsapp), Grab, etc ... all the same.
Just try telling a friend on Whatsapp, eg I want to buy a pair of Nike shoes. Then talked about price range or whatever.
After that, go to your Facebook. You'll probably see advertisement on track shoes or Nike shoes.
yes that's why I surf Facebook on browser instead. no such problems.
cscs3
【购买理由我对手机需求:电量足,最好能扛两天,最差也得24小时,因为经常夜班连轴,所以像iphone那种10个小时没电的家伙用起来真是要命。双卡:还是工作原因,一个私人卡,一个单位卡,24小时oncall照相:还是工作、工作原因,经常有大量拍摄临床照片的需求,所以相机好,才行。外观】,点击链接再选择浏览器打开http://c.b1yt.com/h.QKsP3R?cv=7xsXZydPCrm&sm=db8a67 ,或复制这条信息¥7xsXZydPCrm¥后打开👉手机淘宝👈
cscs3
Thats right. As long as you are on network.
