Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 3
ZrE0_Cha0s
Another problem now ... my 4 years old intel SSD with windows 7 can't work on my new pc... can't detect to install windows 10 OS but work perfectly fine in old pc when I plugged it back
ASRock AB350 Gaming K4 + Ryzen R5 1600 (6 Core 12 Threads up to 3.6Ghz)
The reason been is that current hardware support only windows 8.1 (maybe can) or windows 10.
that's why when u plug in a win7 OS into the system, it wont be able to detect.
ZrE0_Cha0s
Hi guys, looking for a build within 2k, usage for gaming, no intention of OC-ing.
Currently threw together the following:
ddr4 kingston x2 8gb
samsung 250gb ssd
seagate 1tb HDD
gigabyte itx 1070
corsair cx650w
asus prime b350 plus
ryzen 1600
Would appreciate any and all help/advice, and also suggestions for a sound and wireless card.
Thanks!
but how much is your following items price?
next any reasons u would like to get a sound card?
as for wireless card, how far is your router away from your pc? if its quite far and have a few walls in between, even the best wireless card, may not achieve your expected speed. but if u are doing it for gaming, best played it on LAN connections.
bleahhs12
For the prices,
drr4 kingston 8gb x2 - 198
samsung 250gb ssd - 149
seagate 1tb - 72
gigabyte ITX 1070 8gb - 669
corsair cx650w - 119
asus prime b350 plus, ryzen 1600 (Bundle) - 479
Totalling to 1686
Came from laptops, so thought a sound card is a must, apparently it isn't so scratch that. Any better set-ups or cost-effective suggestions are appreciated. Would also like suggestions for a case.
Cheers
ahb1245
Any good cheap monitors to recommend. My first build, budget $100+. Also need keyboard
ZrE0_Cha0s
u can look at viewsonic, should be able to fit your budget. keyboard have any preferences type? else can get a cheap logitech kb.
ZrE0_Cha0s
For the prices,
seagate 1tb - 72
Totalling to 1686
Cheers
well even for laptop their sound card is embedded to the mobo as well.
but base on your budget u can get definitely can get better specs. but is the gpu a must for u? i mean that itx 1070? or u just grab whatever u think is within your budget?
ablue15
Im also having this issue. I want to place the pc in the living room.
Good to be small & compact. I also don't play games.
Is it more economical to DIY a smaller flat bed cpu or just buy this Asus kind of mini pc.
My concern is more on the video/sound ability to display good 4K quality movies from pc via HDMI.
Hi, appreciate if anyone can recommend a simple setup using m-itx case? PC will be more for home entertainment (movies, music). Or am I better off just getting a Asus vivomini PC? Budget around $700-800. Thanks.
joshuaho
Mobo + cpu: MSI h110i pro ac + G4560 $217
Ram: 1x 8gb Kingston 2400mhz $99
Case: in win choppin (someone else advise on where to purchase and if there is PSU provided)
Ssd: WD green 2.5" 120gb $88
Hdd: Toshiba 2.5" 1tb 7200 rpm $63
Os: windows 10 (carousell) <$20
Total: $487 (excluding case, PSU and OS)
Prices provided are based on PC theme unless otherwise stated.
ZrE0_Cha0s
can check with AIM resources, as for the PSU does comes with it. (base on the website of IN WIN.)
ablue15
Thanks Boss,
Noob Qn, why SSD + HDD?
Why not solely SSD as SSD is faster?
Normally use SSD for windows, HDD for backup storage?
phucth91
Budget $1000, already have 2TB HDD, only for gaming, would like 16GB ram, need a monitor. Any suggestions?
Skyrim special edition ultra settings smooth at full HD possible?
Second hand market?
-Synchronicity-
Try 2nd hand.
A decent 24" monitor is like 180? 16gb ram even budget ram set you back 200. For around high-ultra you need at least 1060 3gb but considering mods, maybe 6gb version which costs around 420?
You left 200 for mobo + processor + psu + case + os or any other accessories like wifi dongle etc. Didnt even include a ssd...
Alternatively, lower your expectations or save more money first? You cant expect too much from 1k
joshuaho
***updating***
Found out that make fine has this case, so it's more convenient to purchase :) and yes 150W PSU is included!
Even second hand, unless u are Super lucky and able to meet someone who is selling his parts dirt cheap, $1k Budget hardly able to get a setup to run a modded skyrim at ultra setting
Second hand market?
phucth91
Try 2nd hand.
Ssd not necessary and I can buy later, keyboard mouse dongle and os already have.
I only use gameplay mods, no graphic mods. If only one 8gb ram stick possible? another stick can be bought later as well.
-Synchronicity-
Then you have 300 to get you a g4560 + asrock h110 motherboard + techware f3 + fsp hexa 450
bryanlam25
Hi guys, I need some advice for 2k to 3k range of gaming desktop.
Including monitor, OS. And not going for OC type.
sandwich
Advice on replacement
Hi, I am currently on the following specs which has lasted 5 years.
Intel Core i5 3470 & Asrock B75 PRO3 M
G.Skill DDR3-1600MHz 8GB (2X4GB)
Recently, the PC has repeated random occasional BSOD and will keep restarting without reaching boot screen. I have done bread boarding (but realised this mobo no speaker) and the problem recurs when I attach the ram (both pieces solo at various slots resulted in the restarting syndrome). Noticed quite a few users here experience this problem as the PC gets old.
Can get some advice on what will be a suitable replacement spec please? I only use PC for internet surfing now, no more gaming. Am looking for value for money and reliability (would be willing to pay more if any particular brand tends to last longer).
Will also need a PCI slot for creative soundcard.
Thank you.
:o
Hua_Hui
hi guys what's the most value for money storage now?
is it still HDD? or shift to SSD already. out of touch as it's been a while since i read up on parts
