gregory_choo
- Nov 7, 2007
Final draft as what i meant.
Each point will connect directly to Data point, bypass the Switch.
The Data point will have a splitter/combined,
TThis will enable both tel & data into one data point.
As for the other end will have another to connect to both tel and computer/router.
Don't think it is a good suggestion to use phone/data splitter/combiner because is will reduce lan speed to 100Mbps. This device was used in the past when the lan cable was cat 5 and speed requirement was not high.
If you want to use analog phone (note: your ISP provides you with digital phone service, but after the ONT, it become analog phone), it is better to install additional cable to the rooms, tel cable are cheap, laying of tel cable is free if it is done together with the data cable to the room.
I may need to install a router in this case
