Singtel Wifi Gigabit Router AC1900! (Arcadyan)
renfred89
Yea rebooted. Restarted ont too.
then either the router or the connection itself has an issue. try using another PC or another cable to test.
wireless speed test is not accurate cos you wouldn't be able to rule out any interference etc..
slowchemical
Ac plus router now only show 1 network ssid name? My previous router got 2.4 and 5 able to choose. But not now.
orpisia
High Honorary Member
my router is singtel ac plus, which type of receiver should i get? minimum ac1200? current receiver too old wireless-n
wisco
My new ac plus doesn't come with telephone port? How to connect telephone.
And my otn is still white color type, different from the one shown in ac plus manual..
dreamer_toons
Call Singtel to port your tel line to the ONT at their end, if you have not done so. Then connect the tel line directly to your ONT.
I was using the white one till I did a 1 - 1 replacement at 313 recently.
renfred89
There is no official guide, you can contact 1688 for the basic set up, or find your way through..
Ac plus is an OEM router unfortunately, which runs on customised firmware, so arcadyan website will not carry the user manual..
Hi
Does anyone know where to download the user manual for AC Plus? I went to the official website below and could only find an installation guide. I am trying to find more information on the VPN and Bittorrent function.
https://www.singtel.com/personal/support/broadband/routers-ont/arcadyan-ac-plus-guide
yankees27sg
I just re-contract my 500mbps to 1gbps, change the old modem Aztech FG7003GRV to AC Plus provide by Signet. So far so good after disabling the "band steering" stuff.
My question:
Can I re-use the FG7003GRV as AP hooked to 1 of the gigabit switch that was connected behind the router (to cover WIFI blind spot)?
Thanks in advance.
ZrE0_Cha0s
My question:
Thanks in advance.
Should be can. Iirc someone on one of thread said that u can use it as ap. By disable certain settings.
renfred89
You can, but the performance may not be reliable..
My question:
Thanks in advance.
yankees27sg
thanks for the response, manage to get it done by using the following method
playerdude2010 wrote:
Hi dude, It's super-easy .
1. Plug it into your LAN(use one of the yellow ports)
2. Log in to your main router , locate and find the IP Address of FG7003GR(AC)
3. Log in the IP Address of FG7003GR(AC)
4. Choose "Home Network Configuration" tab,
5. Choose "Connection Type" (Auto/RG/AP). Choose AP
6. FG7003GR(AC) will reboot as an AP!
there are no step 4 & 5.
additional step:
1. Disable DHCP
2. Set static IP
so much better than my range extender, tks
Tokieda
i also disabled band steering, but i still find the connection to be worse than the old aztech i had.
kohkohnut
Thanks for the information. Any idea what the Bittorrent function is for and how it works?
