Official MIO TV Thread.......
renfred89
Meaning the wifi mesh nodes must have optimum connection with each other before the singtel tv will work. You can’t have an already weak wifi connection to begin with..
SingTel doesn’t recommend singtel tv to be on wifi because the performance is always unreliable when customers keep demanding wifi setup to be as reliable as cable. You go singtel shop you’ll hear all those demands already.
To the moral of story is, yes airties do support singtel tv but it has to be connected to a singtel router with good connection between the nodes..
Thanks!
What do you mean
Did you have to set it up yourself or Singtel? Did Singtel recommend this set up?
(Sorry to be a pain, but the counter guys refused to acknowledge that this would work - which pisses me off, as I think they are really trying to force me to give up my unlimited plan)
WestGuy
Sad. They cut off History channel for me.
Thought it would have been included since i was already on the most expensive Jing Xuan package
yperic
Me too I on jing xuan value also can not see the history channel
WestGuy
Saw Singtel TV’s ad, the History channel package is selling separately for $6.90 a month :(
No more Pawn Stars, Storage Wars and Counting Cars :(
WestGuy
It happens to me a few times, random occurrences. My setup is on wired connection.
The screen would freeze momentarily 1 - 2 seconds and it moved on.
Is it just me, or is has this problem been quite prevalent these few days, especially today?
Tried AXN, Discovery Channel etc...
WestGuy
Sometimes it freezes and recovers after a few seconds. And sometimes it freezes and doesnt recover, need to switch channels
renfred89
restart the router and the set top box already?
i did get some squares before but restart router and set top box is okay already..
Norman Chan
Tonight will try power off the fibre modem , the wifi router and the TV box. Than power on again to see any improvement.
By the way , you guy that had the lagging , which area you guys staying ?
I am at Yew Tee area.
xiaochefy
Good evening to all,
I have tried multiple times to search for help in regards to using 3rd party routers for my singteltv and internet.
However i have an concern and i hope you may be able to assist me in my matter.
I am shifting house pretty soon (newly BTO flat, all rooms have data points). I have 2 x Mio Tv Set Up Box intended (1 living room, 1 master bedroom). In order to have this configuration, i am required to stuff my singtel router into the DB box.
However if i were to do this, WIFI signal will be compromised. I would like to seek an advise from you if i am able to utilise 3rd party router, if i am able too than i will be glad to purchase additional router to boost my house internet activity too.
I am hoping to hear from you guys soon. Thank you all and sorry for the inconvenience caused.
Regards.
xiaochefy (new user)
xiaochefy
Hi, i would like to check if you are utilizing 3rd party router? If you are, you can try removing it and restart your whole system and trying it again.
previously i was using a 3rd party router for my room to boost the WIFI strength. However for some reason, i was facing the same issue as you. After which technician came down and let me know that after removing my 3rd party router (Asus). it worked perfectly fine.
So please try it out.
Regards,
xiaochefy
renfred89
It’s best for you to surf the singtel router into the db box and turn off the wifi. Instead, get a wireless ap for your wireless needs..
Regards.
xiaochefy
Good evening renfred89,
Can you please enlighten me? I understand i can keep my singtel router into the DB Box.
Would like to check if i were to utilize a 3rd party router. am i still able to utilize my singtel tv?
Sorry for troubling you haha.
renfred89
I would suggest you connect the singtel tv with the singtel router which terminated at the db box. Do not attempt to connect the singtel tv to a 3rd party router because it will not work. You will need a managed switch in between which complicates the whole thing and you’ll need to spend more..
Cyberboy128
Presently I have Singtel fiber. (my plan allows me to use own router without VLAN)
I have signed up for MIOTV and salesperson told me that their set top box will connect directly to port 2 of the same ONT. This setup does not require their router or any VLAN.
Anyone on this setup?
renfred89
It’s common for singtel tv to be provisioned at ONT, specifically for those who has unlimited fibre and yet requires a singtel tv, or for those whose router is at a different location.
Where the singtel tv is provisioned at, it doesn’t matter as performance will not be affected.
