What's the full model name ?
B315 - xxx
Hi, I had bought a 4G LTE router on line from China. But not able to use when I put in the SIM card. The router is Huawei B315. Please kindly advise how to make it work. Thanks.
How to switch?check that you have switch the region to singapore.
Sorry bro, need your advise on the procedure how to do. We had login before but not able switch. Thanks for your advise.log into the GUI and change lor..
The model is B315s-936
We had tried, but it does not work. It seems not able to recognize the SIM card.It should work on all the 3 telcos, provided TS got the APN correct.
All 3 are using B3 LTE.
Sorry, not sure. Is there a SIM lock?Than is the device sim lock?
I did not see any SIM lock. How to unlock.Lock at the firmware level. Kinda similar with the USB dongle, where telco lock them to only able to use their own SIM card.
I had inserted Singtel SIM card into the router. But it does not work. The power indicator did lights up, the network indicator lights up in red, the Wifi indicator lights up, the LAN and signal strength indicators did not light up.
Is the SIM card in good working condition and test it on the phone to check, including to surf internet for connectivity.
Most likely it is due to SIM card or not insert properly to the slot, as unable to detect refer to the network indicator is red.
If not you may have to test with another working SIM card.
If the SIM card is used, then use a eraser to polish the gold contact & clear the bits before inserting in.
The SIM card is in good condition. Can be use with a dongle. Had tried with different SIM card.
