Huawei 4G Router B315
ECTAY@VHF
Hi, I had bought a 4G LTE router on line from China. But not able to use when I put in the SIM card. The router is Huawei B315. Please kindly advise how to make it work. Thanks.
magix
Have you configure the APN setting on the router
What the error you getting? Any screenshot?
Lastly did u check if the router support local LTE bands
ECTAY@VHF
I did not check whether the router support local LTE band. This is what I suspect that it is not compatible. Can anyone advise what should I do.
deathblade82
What's the full model name ?
B315 - xxx
Huawei LTE CPE B315 modem Technical Specifications:
* 4G LTE Category 4 CPE
* Huawei B315s-22: 4G LTE B1/B3/B7/B8/B20 (FDD 800/900/1800/2100/2600MHz)and TD-LTE B38 (2600MHz)
* Huawei B315s-607: 4G Band 1/3/7/8/28/40 (FDD 700/900/1800/2100/2600 & TDD 2300Mhz)
* Huawei B315s-936: 4G Band 1/3/40/41 (FDD 1800/2100 & TDD 2300/2500Mhz)
* Huawei B315s-608: 4G Band 1/3/5/7/28 (FDD 700/850/1800/2100/2600MHz)
renfred89
check that you have switch the region to singapore.
ECTAY@VHF
I had inserted Singtel SIM card into the router. But it does not work. The power indicator did lights up, the network indicator lights up in red, the Wifi indicator lights up, the LAN and signal strength indicators did not light up.
eric3743
Is the SIM card in good working condition and test it on the phone to check, including to surf internet for connectivity.
Most likely it is due to SIM card or not insert properly to the slot, as unable to detect refer to the network indicator is red.
If not you may have to test with another working SIM card.
If the SIM card is used, then use a eraser to polish the gold contact & clear the bits before inserting in.
Do download the manual for clear explanation.
> https://www.manualslib.com/manual/1316265/Huawei-B315s.html#manual
> https://www.m1.com.sg/Personal/TechSupport/~/media/Files/M1Portal/Personal/Tablets%20and%20MBB/B315_installation.ashx
Look for the sticker on SSID passwords pin stated on the router.
ECTAY@VHF
The SIM card is in good condition. Can be use with a dongle. Had tried with different SIM card.
