Google Pixel Phones 2016
Which model are you hooting?
  • Pixel 32GB
    Votes: 45 15.9%
  • Pixel 128GB
    Votes: 53 18.7%
  • Pixel XL 32GB
    Votes: 44 15.5%
  • Pixel XL 128GB
    Votes: 141 49.8%
  • Total voters
    283
absolut777
Suspended
GPay won't work. Bank apps rolled back also. Outlook app also fc. Fingerprint unlocking bit lag also.
kEvinErd
I read that Google Pay will work on the current Android P Developer Preview version if the bootloader is locked. Is yours unlocked?
absolut777
Suspended
Hmmm, there's confusion about this locked/unlocked. Perhaps I'll just toggle it to test it out.
GoldenStars
Can OG pixel use a USB c to 3.5mm jack adapter to use earphones through the USB port instead of earphone jack? Quite stupid I know but my earphoen jack seems to be having a lot of issues
Sent from Xiaomi REDMI NOTE 3 using GAGT
Mecisteus
I don't think it will work.
I tried to Google.
You can try at the shop before buying though. There is no harm.
Audiology93
Tried my xiaomi dongle but it didn't work.
Sent from HUAWEI MATE 10 using GAGT
GoldenStars
I tried to Google.
Ok thanks for your help! Seems like my pixel gonna become a media player already only speaker left
Sent from Google PIXEL 2 using GAGT
Alexz_Hong
Have you tried the pixel 2's adapter? If I recall correctly it did work with the pixel 1. Sadly don't have one to testnow to confirm. But I can confirm xiaomi adapter from mi6 won't work since there's no DAC inside. Think need adapter that supports the proper usb c audio protocol or what. I was able to try using xiaomi's usb c ANC earphones, and works with first gen pixel.
kaizren
Been using a second-hand 32gb pixel for like 1year now. Still not encountered any problems!
PsyClick
Anyone using the latest os having issues of battery draining very fast? Mine can't last 2 to 3 hours per full charge.
Contemplating to. Change battery at 3rd party if it's batt issues
Sent from Google PIXEL using GAGT
Mecisteus
I don't think it is so much related to the OS.
Most likely your battery has "worn" out.
You can consider changing the battery at breakfixnow.
I changed the battery for my 6P with them. So far so good.
PsyClick
Thank you for your reply. With your confirmation I will be going there for replacement. Trying to avoid the never ending chase for new phones :p
