HDTV talk - antenna and reception issues [consolidated]
gregory_choo
Guys i bought the wrong antenna those needed type connection de any change to make it work?
change connector if you know how to do it.
if not, buy connector adaptor, it can convert the connector to the right type.
Durian Shell
低層住宅單位接收唔到數碼廣播訊號係正常嘅。如果天綫無駁USB供電加強接收能力,根本無用。而且你提到以上嘅西北區,近幾年新組屋林立,越建越近大大削弱天綫接收能力。。。就算有駁USB電源加強也會軟好多。。。
IMDA送嘅天綫如果同提供嘅接收盒同屬原厰貨,接收能力差,用戶就無得爭啦。但係,如果提供嘅天綫係非原厰嘅。。。俾人挑,係唔係應該咧?
Please do a research and read through all I post before you comments. Thanks. another smoker. 現在我挑你!!!! 係唔係應該咧? Hahaha
The IMDA's set top box, already build in antenna's power and please watch the video again.....
https://www.youtube.com/watch?v=IYE-8Jb-i4g&feature=youtu.be
kelvinsin
Just use your smart tv to get the channels from internet.
No need to worry where you staying and how your antenna is facing.
If watch football, internet streaming slower 1-6mins. You wont hope to hear ur neighbour celebrating the goal while u still see the players chasing ball..
Medicated Oil
High Honorary Member
I am chilled as long as I see how the goal is being scored.
No difference to my life if I know it immediately or a few mins later.
Soccer is no longer life and death for me any more.
sunsetbay
Moderator
Moderator
What is the brand of generic STB?
no brand~ bought at aliexpress in 2013, still working as in today~ you can get a better model that covers DVB-T2/S2/C if worry starhub cease its cable broadcast~ :s22:
mun_hoe
guys, which digital antenna recommended for LG OLED55C7T? too many choices with price varies.
cscs3
But you are limited with internet bandwidth.
AND how good and stable your internet service provider.
jkohlc2
Any recommendations for a tv antenna? Received the imda letter :o
Hua_Hui
this M1 antenna that they give for free is crap..... even when i place it OUTSIDE the window, the reception is still fuzzy.
gregory_choo
do you have a digital ready tv? or a dvb t2 set top box?
are you tuning to digital tv?
digital tv cannot be fuzzy, it is either can see or cannot see.
gregory_choo
After installing the digital antennae, the tb image is clearer but lags. Is this common?
what is the brand/model no for the antenna? have you connect the power to the antenna or plug the usb connector to the tv?
what is the meaning of lags?
sugaricing83
Super dulan. Digital tv like worse off than analogue. The scenes keep freezing.
