Creative Outlier Air truly wireless earphones
uplorry
Suspended
I found when disconnecting Bluetooth, the vocal say disconnected is very loud.
Anyone found how to reduce the vocal volume?
Had this problem with the Jaybird X3 too... but couldn't be adjusted... :o
3xistence
I went to try at the show just now but find the sound a bit too bright. i still prefer my existing gear icon x over this but then gear icon x cost 75% more.
galliano
Anyone tried putting 1 of the bud back to the case and use only 1 bud (like typical bluetooth headset for calls)
Will the other bud automatically connect back once u take it out of the case again?
Keen to know if can use with only 1 side.
Been using Jabra Elite for almost 2 years ($268 back then), served me really well during my regular jogs. But I always only use the right side as I prefer to keep 1 ear free in case of traffic during runs.
tmxgkh
Guys, can check out this post for some tips to buy it for $97, slight discount but better than nothing! Can't post links yet but it is: techjio[dot]home[dot]blog
qwerty_hippo
Any one facing video latency issue (eg Netflix YouTube) when used with iPhone?
How is the audio quality compared to those sub-$50 China TWS earphone eg AirDots QCY T1C?
Very tempted to purchase this
Computeron
I have one tws. Sq sucks. Watch video also lag. Now collecting dust on my aelf
Sent from Vivo NEX S 256GB using GAGT
kazuki666
Btw, when I was at the IT on Friday. The staff told me first 500 sets can be delivered in two weeks, subsequent orders will be on one month liao.
Anyway, does earbuds like Outlier Air get software? If yes, how they do it wan???
chesterqw
Hey.......since u've the x mini, can u comment on the quality of music being played from both? Is the Outlier better? The x mini drop outs is a known issue but I've learn to live with it and it's useable most times.....though disappointed. Hoping the Outlier is the one tat I'm looking for.
i have no idea where my x-mini is :x
but the connection is so much better i don't bother to find my x-mini :x
Streetwise
Thanks anyway.....I've pulled the trigger and purchase online. The many positive experiences of others sealed my decision =:p
today tried in the gym, the connection still stays from one corner to the other end while doing workout
uplorry
Suspended
Are there any alternatives to the single ear tip size that they provide? So far everyone who received them seem to have a good fit so I think maybe it's well designed and not an issue at all.
I'm having fit issues with my current NT100 so I ordered this in hopes that it would solve the discomfort.
RocketBunny
The icons on the case means what? The guide is complete ass. I don't understand **** lol
wwf
My review so far
The good,
Sound quality closely resembles the outlier one plus
The earphones very secure, did not shift during jog
Even when sprinting did not fall out, I was still worries may fall
Very shiok without wire, when jogging no wire, controller tug, hitting your face.
Very comfortable without anything on yr neck.
Sound isolation is good
Must have for gym and jogging.
Price wise at $99, I would say value for money.
If you are looking into high quality sound when doing sport, then of course you need to buy others brands.
If you are focusing on yr sports and don’t mind a not bad sound quality, this is a buy.
The bad,
Left earphone suddenly no sound when jogging, work fine after re pairing
Hope it’s a one off glitch.
When paring with iPad, it’s show connected but appear another prompt say pair headphone?
If you click ok, you end up with another Bluetooth device headphone, which is weird.
Click cancel instead
Press and hold to turn off and on volume hard to control to turn one notch up or down.
The case led.
From what I see,
L and R blue means charging the earphones, the earphones battery is more than 30%
L and R red means charging the earphones, the earphones battery currently less than 30%
The battery indicator light blue when open means the case battery more than 30%
The battery indicator light red when open means the case battery less than 30%
The charging led blue means charging case battery, more than 30%
The charging led red means charging case battery, less than 30%
The L and R and charging led not lighted means fully charged.
