gheesung
I think you are right... the best would be cut off power when temperature reach 25 and restart when it’s 27 (example). Wonder does it waste more electricity this way....
Just trying to play around with all the possibility to see how much automation can be achieved.
I will set my A/C to cut off after a certain temperature is sustained for a period e.g. about 25 for 30mins and turn on the fan. Using openhab, the historical readings can be logged to database such as influxdb and you can tune your parameters accordingly.
porker997
Hi guys,
What IR blasters are you guys using for aircon?
I tried the aztech cube...but wondering if there are better IR blasters out there. Came across the broadlink mini which looks nice.
TIA!
Nainai
Hmmm this makes more sense....
Temp =<25 for 30min cut power....
Temp > 25 for 5min open power
pustefix
I am also using RM mini 3 in every room. However I have replaced 4 of them after using for less than a year, do you guys have the same issue or it is just my luck. Mine has no warranty.
viix
USB adapter problem? I notice using cheapo USB adapter is a no go. For all my devices, I purchased a proper USB wall charger. Some of the ones I use are the official raspeberry pi power adapters, ANKER wall chargers.. I use a keweisi USB tester to check they supply the correct voltage and ampere.. those cheapo chinese adapters and some power strips with USB points cannot make it. Either voltage not regulated or cannot supply a proper 1A..
ksksksks
I have them for more than 1 year and still working fine.
They should come with 1 year warranty also
pustefix
Hmm, you have a point, I am using the USB point on the LDNIO power strip. Let me check with my USB tester too.
viix
Can elaborate more on node red on raspberry.
I use stringify because I use it to poll weather data previously.. now I use node red and do a 5min interval http get request and I use it to identify weather conditions to set certain presets.. then i use webhooks to trigger homey.
I could use mqtt but lazy to convert it over until I can get hassio to boot on the RPi..
HexenHeretic
Anybody managed to get the locally sold Mi Sensor set or the Mi Control hub working with home assistant?
According to what I read online, some or the new models have LAN control disabled?
Superaitaotao
Just managed to integrate my Xiaomi gateway to HA last weekend. Yes, the port 9898 is closed and I had to follow the online instructions to do some soldering + transferring commands to open the port. You can read about it at the HA aqara page.
gheesung
I bought another one beginning of this year from Aliexpress and I am still able to control it via openhab.
Nainai
Hi anyone know whether is there square smart downlight? Tried googling but seem like all I got are circle
pustefix
I think there are different versions of Xiaomi gateway, some of them will not be able to work with HA/openHAB. e.g. the Aqara gateway with HomeKit support (with Aqara word on the front of gateway) is NOT supported. The SG/EU version with model DGNWG05LM (EU 2 pin plug) seems to be not supported too as there is no about page (https://community.home-assistant.io/t/not-able-to-get-xiaomi-gateway-key/61795/90)
CyberMew
Thinking of getting a homey and Xiaomi switches (cos they are cheap), will there be any problems? Is this recommended? Do I need to buy a Xiaomi hub to control those ?
