tian800
Just trying to do a quick survey here. Which setup do you guys normally use.
1) smart switch + dumb light
2) dumb switch + smart light
3) smart switch + smart light
Please share your experiences, I'm still trying to decide which setup to go for. Thanks!!!
Superbigfatdaddy
Personnally, I'm retrofitting my own house, I'm going for dumbswitch + smartswitch + dumblight which gives me less modification work to do.
As a new home, personally, I suggest smartswitch + dumblight.
Dooley
I,m using smart switch + dumb light.
Sent from Huawei using GAGT
wahjohreno
Smart switch + dumb light. Works perfectly. Been 2 years in the Fibaro/Alexa ecosystem, and I wouldn’t change a thing.
xenshix
Water heater timer switch
Hi Everyone,
I looking for a solution for my home storage water heater as sometimes my family and i forget to off at times. I looking for a timer switch where crank or turn manually the switch etc within 20 mins it would automatically off. Refer below for reference but sadly after some googling here and there the company in singapore don't do.
Then i found a wifi smart switch which have a timer function in the program but i have no idea does it work like the etc i switch on then after 20 mins later it would automatically switch off.
Please advise if you have experience in this wifi switch.
Thank you.
Superbigfatdaddy
Hi Everyone,
Thank you.
You can easily find normal power plug with timer features in lazada
DragonFire
smart switch, smart driver -> dumb light.
Drivers wired into DALI ecosystem and fronted by KNX logic control.
Makes em controllable by manual switches, logic controllers, or 3rd party devices like Alexa.
squidy
Homey can direct integrate with Google assistant already? Anyone tried that? No more "hey Google, tell homey to turn on the tv". Can go straight to "Hey Google, turn on the TV"
Igene
Moving to a new house so thinking of investing on smart home. Totally have no idea what I need to make it how I want at the moment. :o
Requirement very simple. Control, air con, lights, TV/Radio, door lock from a single controller.
Able to do wiring if needed as contractor not started work yet.
Control from mobile phone is optional.
TIA
zoneguard
Make sure you find a timer switch rated for a heater. Storage heater frequently uses 20A connection.
Heater switch is rated 20A and double pole - controls both live and neutral connections both of which are connected to the MCB at end end and other end goes to storage heater. Will be challenging to find a Wifi switch that meets the requirement.
Hence the alternative solution is to fit electrical contactor that is double pole. Wifi switch (low load) will control the contactor which in turns control the high-load storage heater. For this type of work, it is advisable to get licensed electrician to install.
You may want to source from Aliexpress for a 3B+ model instead. The charger is optional if you have a spare handphone charger and micro usb cable.
this one better right?
yeah I have adaptor
I tihnk microsd better buy locally
gheesung
yeah I have adaptor
I think microsd better buy locally
Aliexpress has lots of options for Raspberry PI. Choose the cheapest.
I bought my Sandisk 16 GB SD from Aliexpress too. I have used it in my Raspberry PI running Openhab for 24x7 for abt 2 years and has no problem. Get those Sandisk w A1 model. It is supposed to be built for frequent read/write.
Superbigfatdaddy
TIA
You can email me at at.ajzpl@gmail.com to find out more.
LoneTraveller
Hello everyone! Apologies if this has been asked before, but I really couldnt seem to find my way around searching this thread. I was wondering if anyone has every tried installing the Xiaomi Aqara light switch in their homes?
I was wondering if the switch without the neutral wire would be compatible with most lighting or would it cause flickering of lights if I do not use the special dimmable LEDs?
Or worse, has anyone experienced fires, Connection failure, long lags with the Aqara switch as well?
Suggest you go Qoo10 or lazada and look for seller passion home or passion home gadgets. They have a disclaimer on this product.
