[Review] Asus RT-AX88U
uncle_josh
anyone of you encounter the internet led turn red out of sudden? encountered quite few times, had to reboot router to resolve.
had changed the cable from ONT to router wan, also tested ONT directly to laptop to test internet also working. just the internet went off in the router.
Could be a sign that your router going to uplorry if it is frequent. Call your ISP for replacement.
Sent from 今天工作不努力, 明天努力找工作 using GAGT
uncle_josh
Speed is irrelevant especially with only a gigabit router.
In practice, a well made cat 5e cable can support 10Gbps speeds at a short distance.
most ethernet cables you buy from a store/online are not even up to specifications e.g using copper clad aluminum instead of solid copper for the cables and in the case of those flat ethernet cables, no shielding, no cable twist to prevent crosstalk etc
I would agree there are always some black sheep. Most stores/online could still be trusted.
Cat5e is not meant to support more the 1Gbps. If you manage to make it works for a 10Gbps connection, good for you.
uncle_josh
Maybe try update to latest firmware and do a reboot?
Don't teach chewren bad.
You may flash your router but the firmware of the ONT is a NO Go.
dryteletubby
I bought 3 different cat5e/6 ethernet cables from challenger and all 3 were copper clad aluminum cables instead of solid copper cables. I cut the first cable into several 10cm cables to connect devices to my switch and it works fine for that use case. However the 2nd cable can't power my PoE AP properly and the 3rd would constantly drop connections to my PC. I replaced the last 2 ethernet cables with in spec ones from sim lim square and my issues were solved.
If all you do is connect your pc to your router, any cheap cable will work fine unless the length is long.
For PoE and longer runs, those cheap cables that are not made up to spec can't work reliably
I don't think you can modify the firmware on the ONT even if you tried. Those things are locked down by the ISP
phayze
How long were your cable when it gave you problem?
Lucky177
Xaiobai asked any setting can do within the router...
Spectral said internet went off in the router.
So I thought was talking about the router for both cases. Hence, my suggestion about the update was actually referring to the router. Not ONT. Sorry if I ever misinterpreted and didn’t make myself clear enough.
spectral
this is getting quite often, maybe I will do a factory reset 1st.
fishdundee
Had the same issue too, happen once every few days. Now I set my router to auto reboot once every 2 days. So far looks ok.
It does look like a firmware bug.
HuatKway
I'm using Netgear orbi mesh, wondering if this can cover a 4room hdb? Last time my ac68u didn't manage to reach the master bedroom
xonix
If you place it middle of house, maybe can. But you could pair it with your ac68u ( if you still have it ) using AiMesh.
fishdundee
With this router..
It seems i can never never achieve a link rate higher that 192mbps
With my old router (rt-ac88u) I can get 866mbps at full signal.
Not to mention, at this link rate (192mbps), its impossible to stream a 4k video (50gb file size).
I could easily stream this when using my ac88u
AX-88u firmware version: 3.0.0.4.384_6210
kashix
With this router..
Ur ax is it disabled? You don’t have the clients you try disable first and try again.
fishdundee
AX has been disabled, HE has been disabled
In any case, I decided to flash the merlin firmware into the AX88u, straight away i can get the desired maximum link rate. What is interesting is that I noticed my huawei P30 was connected at a link rate of 1.5 Gbps (with 160mhz enabled), I did not have a chance to stream a 4K video yet to see how it goes. Streaming videos on my nvidia shield tv was drastically improved. I figured that maybe speedtest might not be the best way to validate the performance of the link rate.
The only issue that i noticed now is that it could not sustained the connectivity, it will disconnect occasionally and reconnect again. Resulting in interrupting the video stream.
HuatKway
Some advice needed.
What's the best setting for this router for 5g? Enable 160mhz band and disable HE from what I see are the key changes? Do you all also enabled DFS?
kleave
Hi, I would like to check is there other setting that I missed out because I disabled AX frame and I keep getting the speed around 90+Mbps and I am on 1Gbps fibre plan.
The test client
MacBook Pro 2019 Model
Iphone X
Notebook with AC connection
Thanks.
kashix
90mbps on 2.4ghz?
The test client
Iphone X
Thanks.
fishdundee
The test client
Iphone X
Thanks.
It seems that this router have a special preference for channel 149 in my case, which result in slow performance...
In the 5Ghz settings, instead of setting the wifi channels as auto, set it as channel 36 hardcoded. YOu will see significant increase.
Reverting back to asus official firmware caused my wan ports to be down once every few days, and i need to reboot. Merlin seems stable but wifi signals tends to drop when there is a huge file transfer.
Honestly,at this point, I would gladly trade my AX88U for a BRT-AC828U. Getting pretty exhausted taming this beast.
