arctic_silver
- Jun 12, 2006
I think the ugreen brand works with the mi box s
Hi there, I just bought a Mi Box S today from the Xiaomi store. After setting up, I try to go to Settings> Display to change my resolution. But I can only see three options: 1080p, 720p and 480p. How do I enable 4K? My TV is a Samsung 43NU7100 and should support 4K
Really glad that I bought the mibox S instead of chromecast.
Connected the mibox audio output to my audio receiver.
Now I can listen to spotify by casting from hp to mibox without the need to turn on tv.![]()
yes thanks, I used a 3.5mm-to-toslink optical cable.it will be better if you connect to mibox's optical output. just need to buy a cheap cable which costs only a few dollars.
I tried viu free, but the viu tv app from play store didn't work. Not sure if the problem is due to the app or box.Does mi box s works with the viu app?
wanted to get viu premium for kdramas but my current box isn't supported.
Download viu via android tv store but when opening the app it says my device isn't supported.
If mi box s can run the viu app i may considering getting one.
I don't think toggle work with any android tv or box atm. Even on my Nvidia shield, I only get a blank screen
mirroring and casting is two different thingsCasting is a different thing. U can cast anything if your device has chromecast built in. I think he's trying to play toggle directly on his xiaomi tv
These 2 methods work on mibox s for viu free (can try on your current box):
1) install viu on mobile or tablet, then cast it onto mibox s
or
2) sideload viu tablet app onto mibox s, and control the app using mouse or airmouse.
Ok thanks! i guess i need to buy mi tv box s then.if you have premium account, you can view the video on mibox via casting.
just run the viu app on handphone, select the video and press the chromecast button.
yes I posted that same listing not too long ago.. that's the cheapest so far.Ok thanks! i guess i need to buy mi tv box s then.
my current android box doesn't support google casting.
for mi box s i guess this is the cheapest currently yeah?
https://www.qoo10.sg/g/552962197
Anyone has issue with tvbanywhere app from androidtv store where after "returning" to the app, the menu/drama icons don't load at all and it seems to be trying to initialize something? (Spinning bar in the middle)
Only reinstalling will fix the issue.
