wongminmin
- Nov 10, 2014
From what i know about roborock, is they might be blocking overseas users from using China server. So there are chances u may not be able to access t6 through mi home (China) with sg ip address. If u going to buy t6, pls double check with the seller/existing users.Thank you!! Cleared lots of doubts. Since s6 and t6 are both mi home then if i have other xiaomi devices, i shld get t6 right? I remember someone mentioned t6 have to select mi home china server. And s6 select non china will result in other xiaomi device cannot be controlled by the app at the same time. Because other xiao mi devices are china server based.
Sent from the real Queen Of EDMW using GAGT
Yes, if u create mi home account in China region, u can only use China devices.
If u create mi home account in sg region, u can use only the overseas devices.
Will test it out after my house reno is done
