noinimod
Any folks with Yeelight color bulbs and happy with them? Read a few comments about unreliable WIFI connections, bugs or signal loss.
sarusaru
need recommendation for items to use with HA + mqtt2zigbee, prefer to keep everything on local network, ok with zigbee, wifi, BT. No Zwave, too expensive. Feel free to share what's good and what's bad in terms of item recommendation.
  1. wall switch
  2. heater switch
  3. aircon switch
  4. power socket
  5. sensors - light, magnet, temperature, motion, vibration, water leak, fire / smoke
  6. LED light strip
  7. LED light bulb
  8. Fan
  9. Smart lock
  10. Camera / CCTV
  11. doorbell camera
  12. curtain
  13. roller blind
  14. smart TV / projector
pustefix
I'm using HA + Zigbee2Mqtt + Xiaomi Gateway. I'm still using the gateway because Z2M range is not as good and some devices are working fine so lazy to move. Here are some of my comments.
- Aqara sensors are cheap and good, buy a lot of them.
- For aircon and IR, I used Broadlink RM mini 3. Cheap but I have a few that failed to work after a few months, maybe my luck, others seems not to have this issue.
- Wall switch is the difficult one, Aqara non-neutral seems not reliable but the neutral ones well needs to pull neutral line.
- I've Yeelight strips, bulb and ceiling light, they are working fine, need to power off/on once every few months.
sarusaru
Are you using the typical CC2531 usb stick? how's the range like, I cant find much info on the range that is relatable to local env, thick reinforced concrete wall type. Also have you considered soldering a antenna to the stick?
daniel_83
hi people
i'm looking for a suitable smart plug that can connect to my hue bridge
because want to use my hue sensor to trigger on/off
did some reading and think the INNR is suitable but SG no sell eh..
any recommendations for a Hue compatible ZIGBEE smart plug?
viix
hi people
The IKEA tradfri might work if the device is the latest firmware. Plus great return policy from IKEA if it doesn't work.
baineteo
all smart switches cannot direct wire to fans or any motors. u will need to place a relay inbetween
Ar, I see. That must be the reason! What’s a good place locally to buy these relay? I sometimes find neighbour hardware dojo’s don’t really sell these stuff. Don’t want to trouble my electrician.
viix
Color bulbs still ok. Never experience signal loss or bugs.
But their ceiling lamp cmi.. the driver after a year always auto shut off. Due to overheating or something..
Superbigfatdaddy
It depends on which location you are in. Anyway you can try the shop NPE (new prosperity electrical), they have quite a few outlets in singapore.
pustefix
Yes, CC2531 with a casing and no antenna. I've used a USB extension cable so that it is away from the Pi but may not help much as I've a 2nd router at the same place. I can't pair with a motion sensor in one of the toilet, it is about 5m away but there is a thick concrete wall almost perpendicular to them.
bullfrog
Ar, I see. That must be the reason! What's a good place locally to buy these relay? I sometimes find neighbour hardware dojo's don't really sell these stuff. Don't want to trouble my electrician.
If your fan is AC, it is likely. My DC ceiling fan doesn't have such problems though, hence, i need not use relays.
Sim lim tower is where i would go to buy relays.
Posted from PCWX using Me dic stinks
Noirkw
Hi guys & experts,
Getting my house soon and planning to do some semi-automation for quality of life improvements. I am in no way a tech expert, looking for some guidance and advise.
Main things that I want to control are:
Light controls + fan (dumb)
Water heater tank (dumb most likely, may get the digital ones from AOS)
Air-con (daikin ismiles, from what i read, these need a custom device handler)
Vacuum (samsung / roborock)
sonos beam + sonos 1 x 2 (HDMI Arc to TV)
motion sensors are a plus, but not really essential.
Understand from the thread that you can either go
1) dumb switch + sonoff zigbee module (basiczbr3) + dumb lights
1) dumb switch + smart lights
2) smart switch (aqara) + dumb lights
I'm planning to future proof and will be pulling neutral wires across to all light switches as recommended in the thread. I am also into google ecosystem and would prefer to use G.Home.
The one I am confused about is the smart hub, reading from the threads there are quite a number of options - hubitat / homey / smart things / aqara / xiaomi. I know that there is no all-in-one smart hub capable of controlling everything.
I would like something that can be controlled via google and I am inclined towards the UK/EU version of smartthings. From my limited knowledge, I am planning for:
router (ubiquiti) ->
smart things hub ->
dumb switch (sonoff basiczbr3) ->
lights/fans/aircon/roborock
Will google home be able to control these devices via the smart things hub ? As my fans come integrated with an LED light, I'm wondering if the hub can detect the fan and led as separate items?
Or am i better off getting smart switches instead ?
Thanks!
Tmzhen
Hi guys & experts,
Thanks!
Newbie here :s12: I want to ask
(dumb switch + smart lights) = dumb switch need to be turn on all the while? will waste eletricity?
(Smart switch + dumb light) = dont require to be turn on only zigbee/zwave/wifi signal require?
What about Smart switch + smart light?
drkcynic
Dumb switch has to be turned on all the time for your smart switches to be powered.
Smart switches needs to be connected by wifi or zigbee if you want to control via phone so you need you smart hub/wifi on all the time. Once it's off you lose all connections.
You need to think of these smart switches logically, with common sense. Then consider what is best for you and your habits.
bullfrog
Newbie here
:s12:
I want to ask
Yes, always on. Not really wasted as power is needed to keep the smart light listening for activities.
Yup. The switch will always be listening for activities too. However you can walk to the switch and control the lights or use an app to control. More flexibility. But zigbee/zwave switches will need a hub
A bit overkill but not unheard of. My dining lights are controlled by smart switch and smart bulbs. The smart bulbs are there to adjust the brightness. But i need to turn on the lights using the smart switch first.
tengfeng
New bird here, I having issues on connecting my gateway 2 to my velop. anyone have this issues? the same gateway can be connected to my office router, orbi. should I change router?
viix
hi people
Ok email ikea asking about the firmware of the TRÅDFRI outlet as it requires the latest one to be hue compatible but they kept going on about only supporting TRÅDFRI hub. So I bought 1 myself and tested it! it works!
detected it with touchlink as a light and it paired as a smart plug.
As Long as the TRÅDFRI packaging has a stamped batch 1925 and above you should be good to go.
daniel_83
Swee la!
Sent from Samsung SM-G975F using GAGT
eudemon
Newbie to this wish to ask for advice from experienced bros here.
Basically I just need remote controlled switches for lights/fan, eg. phone controlled via wifi, as I always have phone with me (vs a 2-way bedside switch). I am looking a solution that doesn't need additional hub or control system now (compatibility for future voice automation is good to have but not critical). Looking at smart switch rather than smart lights, and prefer to pull neutral wire for switch if necessary.
I looked through the thread and saw lots of options (Aqara, SonOff, Shelly, TKBHome, SmartThings, Zigbee), but want to make sure I get the best/correct option for my needs. Thanks in advance for help!
