- Sep 16, 2018
1. Note: the Asus routers in this thread are all pretty good.
Note: I do not recommend lower end Asus ZenWiFi series like ZenWiFi 4/5/6 (okay as mesh node after a powerful router like TUF-AX6000, RT-AX86U, RT-AX86U Pro or GT-AX6000) as they seem to have multiple issues as reported in this forum, especially when the main node is also the main router.
Note: I also do not recommend Asus ZenWiFi XT8 unless you need to use wireless backhaul.
Note: in general if you do not need to use wireless backhaul with AImesh, there is no good reason to go with GT-AX11000 or GT-AX11000 Pro -- GT-AX6000 will be better and more cost effective.
Note: lower end Asus WiFi 6 routers are covered in the following thread.
https://forums.hardwarezone.com.sg/...ax55-rt-ax53u-rt-ax1800hp-rt-ax1800u.6394549/
Asus WiFi 6E and WiFi 7 routers are covered in the following thread.
https://forums.hardwarezone.com.sg/threads/asus-wifi-7-and-wifi-6e-routers.6952409/
2. Note: Asus China version vs Local version
They are basically the same HW and same FW, just different country code. The country code can not be changed as it is outside of the FW area. The country code will decide the minor differences in the behaviours.
Major difference:
Local version has three years HW warranty. China version will have no local warranty.
Minor differences in terms of FW behaviors:
1) China version has Chinese/English Web UI
2) China version may have specific game accelerator (网易 UU 加速器), just ignore it.
3) China version may ping Baidu for web monitoring but you can change the behavior.
4) Some China version routers may have special Web UI skins like Asus TX-AX6000, which is a bit different from local version TUF-AX6000.
5) China version has wireless region default to China, but you can change to Asia region to be compliant to local regulation.
6) Some reports say that Asus Instant Guard VPN may not work with Asus China routers.
3. More info about higher-end and mid-range Asus Wi-Fi 6 routers
High-end: Asus RT-AX89X, GT-AX11000 Pro, GT-AX6000 (highly recommended), RT-AX88U Pro, RT-AX86U Pro, GT-AX11000, RT-AX86U, RT-AX88U (not covered in this thread)
Mid-high end: RT-AX86S, TUF-AX6000
Mid-end: RT-AX82U and TUF-AX5400, RT-AX5400, TUF-AX4200 (recommended).
Chipset info:
http://en.techinfodepot.shoutwiki.com/wiki/List_of_802.11ax_Hardware
Long range performance for WiFi 6 Routers
From https://dongknows.com/asus-rt-ax88u-pro-review/
Asus routers are excellent choices among consumer routers. They have very good FW features and relatively long term FW support compared to Netgear, Linksys and TP-Link.
FW features: https://dongknows.com/asus-wi-fi-routers-explained/
AIMesh is also a good option to go with, especially when using Ethernet Backhaul and not many nodes (say 2/3/4).
https://dongknows.com/asus-aimesh-overview/https://dongknows.com/best-aimesh-routers-and-combos/
1) GT-AX11000: it seems that there are not many posts about GT-AX11000, so I will include it here. It is very much like a tri-band version of RT-AX86U as the CPU is the same (BCM4908). It has 2.5G WAN/LAN port just like RT-AX86U.
Ref: https://www.hardwarezone.com.sg/fea...gear-tplink/performance-analysis-conclusion-2
2) GT-AX6000 is one of the best AX routers out there in the market. It is even better than RT-AX86U.
It has a higher end CPU (BCM4912) . It has one 2.5G WAN/LAN port and one 2.5G LAN port.
https://rog.asus.com/networking/rog-rapture-gt-ax6000-model/
DongKnows review:
https://dongknows.com/asus-rog-rapture-gt-ax6000-gaming-router-review/
Chinese reviewer's comparison among GT-AX6000, RT-AX86U and Xiaomi AX9000.
3) Asus RT-AX86U Router: one of the best AX routers out there in the market.
RT-AX86S is a cut-down version of RT-AX86U and not really worth the price.
Main advantage of RT-AX86U versus RT-AX88U is the 2.5 Gbps WAN/LAN port, giving it true 2 Gbps networking capabilities for WAN, LAN and WiFi. Whether that is useful or not depending on the use cases.
Dongknows review of RT-AX86U: it was listed as the best WiFi 6 router until GT-AX6000 came out.
https://dongknows.com/asus-rt-ax86u-ax5700-gaming-router-review/
4) RT-AX82U and TUF-AX5400 -- can only be considered as mid-end router compared to the above due to lower end CPU used. But they have excellent wireless performance. It may well be enough for many users.
DongKnows review of RT-AX82U
https://dongknows.com/asus-rt-ax82u-ax5400-gaming-router-review/
DongKnows review of TUF-AX5400
https://dongknows.com/asus-tuf-ax5400-gaming-router-review/
5) TUF-AX4200
Lower wireless spec than RT-AX82U and TUF-AX5400, but with a much faster Filogic 830 CPU from MediaTek.
https://www.mediatek.com/products/home-networking/mediatek-filogic-830
Simple review:
https://www.blacktubi.com/review/tuf-ax4200/
6) GT-AX11000 Pro is now available in Singapore, with one 10G WAN/LAN port and one 2.5G WAN port. It also has the faster BCM4912 CPU compared to BCM4908 used in GT-AX11000.
https://rog.asus.com/sg/networking/rog-rapture-gt-ax11000-pro-model/
Review by DongKnows
https://dongknows.com/asus-rog-rapture-gt-ax11000-pro-review/
Simple Youtube review:
7) RT-AX86U Pro is now available in Singapore, with similar to spec to RT-AX86U but with the faster BCM4912 CPU.
https://www.asus.com/sg/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax86u-pro/
8) TUF-AX6000 is using MTK FiLogic 830 platform with 2.5G WAN x1 and 2.5G LAN x 1(NEW)
https://www.asus.com/sg/networking-iot-servers/wifi-routers/asus-gaming-routers/tuf-gaming-ax6000/Simple Youtube review
9) RT-AX88U Pro is quite good but it is not available in Singapore yet. I actually do not consider it as the upgrade of RT-AX88U as the two are quite different. So it will be covered in this thread.
10) Existing thread for RT-AX89X, it is still the highest end WiFi 6 routers from Asus in terms of CPU power and the two 10G ports. There are not many discussions though.
https://forums.hardwarezone.com.sg/threads/maylyns-networking-asus-ax89x.6089070/
11) Existing RT-AX88U thread -- it is the first AX router from Asus with good WiFi performance. It also has 8 LAN ports. I will not recommend to buy it now. It will not be covered in this thread.
https://forums.hardwarezone.com.sg/threads/review-asus-rt-ax88u.6012723/
Some advanced feature of high-end Asus routers.
1) VLAN -- GT-AX11000 Pro, GT-AX6000, ROG Rapture GT-AXE16000, RT-AX86U Pro, RT-AX88U Pro, ZenWiFi Pro ET12, ZenWIFI Pro XT12
https://www.asus.com/support/FAQ/1049415/
2) Guest Network Pro -- GT-AX11000 Pro, GT-AX6000, ROG Rapture GT-AXE16000, RT-AX86U Pro, RT-AX88U Pro, ZenWiFi Pro ET12, ZenWIFI Pro XT12
https://www.asus.com/support/FAQ/1049414/
Major difference:
Chipset info:
DongKnows review:
5) TUF-AX4200
Simple review:
Review by DongKnows
will wait for the AX86U, tested and proven with performance.
