Asus GT-AX11000/Pro, RT-AX89X, , GT-AX6000, RT-AX88U Pro, RT-AX86U/Pro, RT-AX86S, TUF-AX6000, RT-AX82U (V1/V2), TUF-AX5400, RT-AX5400 and TUF-AX4200
1. Note: the Asus routers in this thread are all pretty good.
Note: I do not recommend lower end Asus ZenWiFi series like ZenWiFi 4/5/6 (okay as mesh node after a powerful router like TUF-AX6000, RT-AX86U, RT-AX86U Pro or GT-AX6000) as they seem to have multiple issues as reported in this forum, especially when the main node is also the main router.
Note: I also do not recommend Asus ZenWiFi XT8 unless you need to use wireless backhaul.
Note: in general if you do not need to use wireless backhaul with AImesh, there is no good reason to go with GT-AX11000 or GT-AX11000 Pro -- GT-AX6000 will be better and more cost effective.
Note: lower end Asus WiFi 6 routers are covered in the following thread.
https://forums.hardwarezone.com.sg/...ax55-rt-ax53u-rt-ax1800hp-rt-ax1800u.6394549/
Asus WiFi 6E and WiFi 7 routers are covered in the following thread.
https://forums.hardwarezone.com.sg/threads/asus-wifi-7-and-wifi-6e-routers.6952409/
2. Note: Asus China version vs Local version
They are basically the same HW and same FW, just different country code. The country code can not be changed as it is outside of the FW area. The country code will decide the minor differences in the behaviours.
Major difference:
Local version has three years HW warranty. China version will have no local warranty.
Minor differences in terms of FW behaviors:
1) China version has Chinese/English Web UI
2) China version may have specific game accelerator (网易 UU 加速器), just ignore it.
3) China version may ping Baidu for web monitoring but you can change the behavior.
4) Some China version routers may have special Web UI skins like Asus TX-AX6000, which is a bit different from local version TUF-AX6000.
5) China version has wireless region default to China, but you can change to Asia region to be compliant to local regulation.
6) Some reports say that Asus Instant Guard VPN may not work with Asus China routers.
3. More info about higher-end and mid-range Asus Wi-Fi 6 routers
High-end: Asus RT-AX89X, GT-AX11000 Pro, GT-AX6000 (highly recommended), RT-AX88U Pro, RT-AX86U Pro,
GT-AX11000, RT-AX86U, RT-AX88U (not covered in this thread)
Mid-high end: RT-AX86S, TUF-AX6000
Mid-end: RT-AX82U and TUF-AX5400, RT-AX5400, TUF-AX4200 (recommended).
Chipset info:
http://en.techinfodepot.shoutwiki.com/wiki/List_of_802.11ax_Hardware
Long range performance for WiFi 6 Routers
From https://dongknows.com/asus-rt-ax88u-pro-review/
Asus routers are excellent choices among consumer routers. They have very good FW features and relatively long term FW support compared to Netgear, Linksys and TP-Link.
FW features: https://dongknows.com/asus-wi-fi-routers-explained/
AIMesh is also a good option to go with, especially when using Ethernet Backhaul and not many nodes (say 2/3/4).
https://dongknows.com/asus-aimesh-overview/https://dongknows.com/best-aimesh-routers-and-combos/
1) GT-AX11000: it seems that there are not many posts about GT-AX11000, so I will include it here. It is very much like a tri-band version of RT-AX86U as the CPU is the same (BCM4908). It has 2.5G WAN/LAN port just like RT-AX86U.
Ref: https://www.hardwarezone.com.sg/fea...gear-tplink/performance-analysis-conclusion-2
2) GT-AX6000 is one of the best AX routers out there in the market. It is even better than RT-AX86U.
It has a higher end CPU (BCM4912) . It has one 2.5G WAN/LAN port and one 2.5G LAN port.
https://rog.asus.com/networking/rog-rapture-gt-ax6000-model/
DongKnows review:
https://dongknows.com/asus-rog-rapture-gt-ax6000-gaming-router-review/
Chinese reviewer's comparison among GT-AX6000, RT-AX86U and Xiaomi AX9000.
3) Asus RT-AX86U Router: one of the best AX routers out there in the market.
RT-AX86S is a cut-down version of RT-AX86U and not really worth the price.
Main advantage of RT-AX86U versus RT-AX88U is the 2.5 Gbps WAN/LAN port, giving it true 2 Gbps networking capabilities for WAN, LAN and WiFi. Whether that is useful or not depending on the use cases.
Dongknows review of RT-AX86U: it was listed as the best WiFi 6 router until GT-AX6000 came out.
https://dongknows.com/asus-rt-ax86u-ax5700-gaming-router-review/
4) RT-AX82U and TUF-AX5400 -- can only be considered as mid-end router compared to the above due to lower end CPU used. But they have excellent wireless performance. It may well be enough for many users.
DongKnows review of RT-AX82U
https://dongknows.com/asus-rt-ax82u-ax5400-gaming-router-review/
DongKnows review of TUF-AX5400
https://dongknows.com/asus-tuf-ax5400-gaming-router-review/
5) TUF-AX4200
Lower wireless spec than RT-AX82U and TUF-AX5400, but with a much faster Filogic 830 CPU from MediaTek.
https://www.mediatek.com/products/home-networking/mediatek-filogic-830
Simple review:
https://www.blacktubi.com/review/tuf-ax4200/
6) GT-AX11000 Pro is now available in Singapore, with one 10G WAN/LAN port and one 2.5G WAN port. It also has the faster BCM4912 CPU compared to BCM4908 used in GT-AX11000.
https://rog.asus.com/sg/networking/rog-rapture-gt-ax11000-pro-model/
Review by DongKnows
https://dongknows.com/asus-rog-rapture-gt-ax11000-pro-review/
Simple Youtube review:
7) RT-AX86U Pro is now available in Singapore, with similar to spec to RT-AX86U but with the faster BCM4912 CPU.
https://www.asus.com/sg/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax86u-pro/
8) TUF-AX6000 is using MTK FiLogic 830 platform with 2.5G WAN x1 and 2.5G LAN x 1(NEW)
https://www.asus.com/sg/networking-iot-servers/wifi-routers/asus-gaming-routers/tuf-gaming-ax6000/Simple Youtube review
9) RT-AX88U Pro is quite good but it is not available in Singapore yet. I actually do not consider it as the upgrade of RT-AX88U as the two are quite different. So it will be covered in this thread.
10) Existing thread for RT-AX89X, it is still the highest end WiFi 6 routers from Asus in terms of CPU power and the two 10G ports. There are not many discussions though.
https://forums.hardwarezone.com.sg/threads/maylyns-networking-asus-ax89x.6089070/
11) Existing RT-AX88U thread -- it is the first AX router from Asus with good WiFi performance. It also has 8 LAN ports. I will not recommend to buy it now. It will not be covered in this thread.
https://forums.hardwarezone.com.sg/threads/review-asus-rt-ax88u.6012723/
Some advanced feature of high-end Asus routers.
1) VLAN -- GT-AX11000 Pro, GT-AX6000, ROG Rapture GT-AXE16000, RT-AX86U Pro, RT-AX88U Pro, ZenWiFi Pro ET12, ZenWIFI Pro XT12
https://www.asus.com/support/FAQ/1049415/
2) Guest Network Pro -- GT-AX11000 Pro, GT-AX6000, ROG Rapture GT-AXE16000, RT-AX86U Pro, RT-AX88U Pro, ZenWiFi Pro ET12, ZenWIFI Pro XT12
https://www.asus.com/support/FAQ/1049414/
JD has the preorder for China version of RT-AX82U AX5400 WiFi 6 router for RMB1399 (RMB1599 usual price, pay deposit of RMB10 to get RMB210 discount).
https://item.m.jd.com/product/100013841642.html?utm_medium=jingfen
China Asus Tmall Flagship Shop:
RT-AX86U -- RMB1799 offer price now RMB1499-1599
JD is selling the RT-AX86U at RMB1599
https://item.m.jd.com/product/100012950722.html
Looks like RT-AX86U is still a better buy.
Product announcement of RT-AX86U and RT-AX82U
https://www.techpowerup.com/268531/asus-announces-rt-ax86u-and-rt-ax82u-gaming-routers
RT-AX86U Youtube review -- initial review and one year after
Good to have separate discussion thread for these ... thank you xiaofan.
I see ASUS Singapore also have listed these in the webpage (Networking->gaming routers)
Can buy from physical shops now.
https://www.asus.com/sg/Gaming-Networking/Gaming-Routers-Products/
Not yet available in the physical shops as far as I know.
I can not find them in Jurong Point Challenger and Best Denki, both are listed in the Asus website.
On the other hand, probably soon they will appear, hopefully the price is not too high compared to the price in China.
maomao82
Let me guess: AX58 $235, AX88 $429 ..
so AX86 ~$350 ???
One of the comparable model with RT-AX86U from other vendors is TP-Link Archer AX6000 router based on the same Broadcom BCM49408 SoC CPU (1.8GHz Quad Core Arm Cortex A53) with two 802.11ax radios - the BCM43684.
TP-Link Archer AX6000 comes with 1GB of RAM, a 2.5 Gbps WAN port, 8x gigabit LAN ports, and two USB 3.0 ports (1x Type-A, and 1x Type-C). It also supports link aggregation, band steering, and DFS. It is at S$296 now as an offer price from official TP-Link Lazada/Shopee Store.
So HW wise they are pretty similar (RT-AX86U is AX5700, lose a bit in 2.4GHz performance but nobody will really care).
kashix
Lol tp link, no thanks :s22: will wait for the AX86U, tested and proven with performance.
Ha-ha, for lower end stuff, TP-Link is still okay. For example the cheap TP-Link AX10 AX1500 is actually not bad considering the cost (S$99 - S$109). And the S$99 per pair Deco M4 mesh is also not bad.
But I agree that at S$296, TP-Link AX6000 may not be a good buy. RT-AX86U will be a better buy even though the cost will be quite a bit higher.
Same for TP-Link AX50 AX3000 (S$189 offer price) Asus RT-AX58U is a safer buy even though it has higher cost (S$208-235).
super365
Saw a video here showing wifi5 314 Mbps, wifi6 893Mbps https://www.youtube.com/watch?v=P46_YITyoZg is it really so big difference?
Saw some comments mention wifi5 and wifi6 speed not really big difference at https://www.youtube.com/watch?v=Llb3512sU1Y
Is it people who use wifi6 router need to subscribe to more than 500 Mbps internet plan (example 1Gbps) then wifi6 is useful to you?
I read most people don't really need 1Gps, 500Mbps is good enough, if you are using 1Gps I wonder why you all need 1Gps?
kashix
I don’t really like tp link. I only buy ASUS for the past few years. Never give me any problems. No point save little bit $ but later problematic. You don’t save on a router, using it daily, later problematic, waste time go troublesome. I see reviews, say good I buy already. Save time, no headache!
kero89
Don't think anytime within the near future i.e week or even weeks ? Till date both routers don't seem to have cleared IMDA licensing yet.
First video is a commercial for Xiaomi, using Xiaomi WiFi 6 router against an unknown competetor's WiFi 5 AC router. Ignore it.
Second video is a commercial for Asus, not really very suitable for Singapore where 1Gbps plan is common.
As for 500Mbps plan or 1Gbps plan, it is not really that related to WiFi 5 or WiFi 6 routers in reality. It depends on your use cases.
The truth is that 1Gbps does not offer much benefits compared to 500Mbps plan. Firstly the international bandwidth for the 1Gbps and 500Mbps plan will be very much similar, well below 500Mbps for most of the international sites. Secondly, 500Mbps is more than enough for most of the things you do. As Netflix 4K streaming uses only 25Mbps. So you can have 10 devices streaming 4k video and yet only need 250Mbps.
On the other hand, it is perfectly fine to use good WiFi 6 router with either 500Mbps plan or 1Gbps plan. Firstly it is easier to saturate the bandwidth and you will feel good. Secondly you may have valid use case for the high speed wireless connection (near 1Gbps) within the household (eg: high speed file copying from NAS to laptop). In this case it has nothing to do with your Fibre Internet plan as this does not go through the internet.
