ahsiao80
- Nov 19, 2010
I recommend you search on YouTube how to setup unifi to get an idea. That will probably tell you if it's too much or just nice for you.
not easy to guide over a forums to setup.
Suggest you check out YouTube video to have an idea.
i need to dig up the pic of my cabling for this home fibre setup inside the cabinet. you will be shocked .![]()
Alright thanks guys! will look up on youtube!
ONT means you can use your powerful router
ONR mean your powerful router must be set to AP mode in order to use. All features of the powerful router will be rendered useless.
Sent from 天作孽 犹可恕 自作孽 不可活 using GAGT
So can i clarify those provided by ISP are ONT or ONR?
1 lite can cover whole house already.
