Mini USB Desktop Fish Tank
yongping79
The plant will rot if you never feed her.
1 time a day, the lionheart is very greedy. Simi sai also eat. You dun appreciate this until you see the lionheart eat sai. Stamina challenging because no place to rest there.
all the sai i see drop into the hole at the base ....
the fish cute right ??
feed only 1 time ???
KnightDroid
You must ja gar properly hor, if got blood stain means hit something liao.
Floating pellets, the one in the photo, all will eat. Not picky.
tankgunner
Mentor
The water i use from the aquarium ... should be ok right ??
So how often i should feed the fish ? 3 times a day ? Change water once everyday ?
the goldfish is swimming happily at his new house:)
i think the plant a bit too big ?
sorry if i sound too direct.
i give your fish one month. :(
Grimz79
If money not an issue I suggest you still look out for a bigger tank, the goldfish quite big leh. Tomorrow go get a bottle of decchlorinator as you will need to do water change regularly, goldfish poo quite a bit so water will be dirty quickly.
Feed him 1 or max 2 times a day, and abit each time only. Don’t leave uneaten food inside the tank. You may want to buy a fish net to help you scoop stuff out.
Lastly, I suggest you just get plastic plants instead of live plant for such a small tank.
yongping79
ok
plastic plant ? the original plastic plant that comes with it ? i threw away just now liao... i thought live plant better ??
KnightDroid
too much light algae hor.....mai happy happy on light...plants only need 2% sunlight to survive.
the presence of light is to aid photosynthesis, which obviously you did not dose the water.
