Hi All,
I just recently re-contracted to get the Starhub TV+ box (Android TV box). I can still watch streaming content but I could not watch the freeview channels (like channel 5.. etc.). I could only do so if I use the smart wifi (Nokia Beacon 1)..
I am happy with my current connection.. Nucleus Connect --> Linksys EA8100 --> LAN/Wireless/Starhub Android TV box..
But Starhub is saying if I want to watch the freeview channels, it would go like... Nucleus connect --> Nokia Beacon 1 --> Android TV box.. The problem with this is... that the Nokia router has only 1 port ....
The solutions are.. buy 1 or 2 more of the Nokia router and configure as mesh.. But I still prefer LAN on some PC's due to latency and throughput advantages.
Another solution might be to buy another 5 port switch and connect to LAN port of Nokia router... Then uplink my linksys EA8100 to the switch.
I am thinking of 2 other ways to go about... 1 is to convert the linksys EA8100 to a bridge.. Will this carry the IP TV signal from Nokia beacon to the Android TV box?
Nucleus connect --> Nokia Beacon 1 --> linksys EA8100 (bridge mode) --> LAN/Wireless
The 2nd method.. Nucleus connect --> linksys EA8100 --> Nokia Beacon 1 --> LAN/Wireless .. But I do not know if the Linksys EA8100 carries/traverses the IP TV signal towards the LAN. The configuration of linksys EA8100 can modify the VLAN.. Same as for the Nokia Beacon.. But I guess this is controlled by Starhub.. So I am not sure if EA8100 can pass the IPTV signal to Nokia and for Nokia to traverse the IPTV signal to the LAN port.
I guess the likely solution is for the Linksys EA8100 on bridge mode? Apologies if this post is very confusing
James
James
