Samsung Galaxy Note 20 | Note 20 Ultra
Xuanrine
The CSO replaced on the spot.
Before they remove the original flim to check if it is dust or scratch on the screen , i got them to confirm they will do a 1-to-1 exchange of the full set if it is a scratch,as it will be unacceptable for me to accept a screen replacement since it was just the 1st day of collection of the pre-launch.
Maybe I was very detailed in checking the phone. Most ppl could not see the little flaw on the screen. Even when I sent the phone in, some of the staffs could not see it too. 😆😅
The CSO replaced the protector for you on the spot? or you do it yourself?
Angtehkor
thinking to buy it
how much did you hoot it again?
Bro I got something to ask you, accubattery monitor drain battery in the background a not. Because some bros tell me accubattery can drain up to 10% just for monitoring the battery.
chanbri
There a couple realiable one . Mercury tech , alpha telecom . I got mine from alpha telecom during 11.11 at 1380. Maybe you can see which one provide the best value for money
Sent from Samsung Note 20 Ultra [SD] using GAGT
Bro you sd set is korean?
Sent from OnePlus GM1910 using GAGT
ryan_khoo
Those who have Note 20 Ultra 5G, can confirm whether you can put 2 different SIM cards + 1 micro SD card ?
Or is 2nd SIM card slot, you can either put a SIM card or micro SD card but not both ?
Thanks
lcheowl
Thanks
is a hybrid slot, so either 2 sim or 1 sim + 1 micro sd card.
1982-1994
can try GSam battery monitor
1982-1994
if the battery graph is like one UI 1.5, then no need to use 3rd party app
Stylebit
Does ah Beng mobile shop accept export set Note 20 Ultra for trade in or sell?
Sent from HUAWEI EVR-L29 using GAGT
Miss D
Hi..Sorry guys stupid question here...
Can my 4g plan/line use 5g phone?
Thanks in advance..
micshang
Just Sharing my experience.
HK, Taiwan and China set also the same model number SM-N9860. But only HK with CSC (TGY) works exactly the same as local sets (except no samsung pay rewards). But Taiwan and China one has the caller id display issue which is explained few pages back.
So the safest way to conclude is, check in the about phone -> software information look for the csc code.
I checked in Sammobile, HK (TGY) and Taiwan (BRI) have the same CSC and PDA. So I download HK (TGY) CSC to flash?
Another question, since I'm flashing the firmware, is there any way I can make Samsung pay rewards work?
lcheowl
Samsung Trade in Program by PC Dreams Pte Ltd only accept local set.
If you trade in at Reebelo, for example, for N10+, expect to get around $100 lesser for an export set.
So I believe, even the ah beng mobile shop willing to let you trade in, you need to let go cheap.
Best is to sell at carousell which you may get a higher than average market rate if happen the buyer know the difference between Exynos set and Sd set.
dgkt77
Wireless Charging
I am using the Samsung Wireless charger stand to charge my N20U. IS it normal for the charger to stop charging at 80%?
dgkt77
OR will it continue to charge to full even as it gave a message to disconnect as charge reached
