Samsung Galaxy Note 20 | Note 20 Ultra
someonetall
understand that HK SDN20U is dual sim and KR SDN20U is single sim.
Other than that still got what differences?
Pricing for KR set is $1229 and HK is $1449.
Any cheaper deal out there?
Galahad
Korea Set: SG phone numbers with +65 won’t display name. Need workaround.
HK set: SG phone numbers with or without +65 will display name. No workaround needed.
nobody44
Hi,
May I know what is the hole that is next to the sim card card? I thought that is the hole to eject the tray and i use the pin to poke it.... siao liao duno will spoilt or not.... very sad now
Thanks
Nobody
nobody44
Mine there is no 5g even I'm in 5g enable area. Tested the speed around 30-40gpbs. Not sure if my model same as yours sm-n986n? Do we need to get 5g sim card or any settings?
Mine SG set but no show 5G only show 4G+ ..... even thou i also on 5G data plan
Some-one
Hi,
Thanks
Nobody
It's used for ejecting the tray
SteveAu
Guys do u think the price will go down further for korea sd set? SD888 launching on jan 2021 for other phones?
nuscape
Hi,
Thanks
Nobody
If u referring to the hole towards to the right side (about 1 inch away from sim tray) then u have poked the secondary microphone?
Sent from Samsung SM-N986B using GAGT
nobody44
Yup i poke the microphone. I call the Samsung tech support , they ask me to test take video and record my voice see its is working. Thanks god it working. I doubt it wont be so easily spoiled ba.....
someonetall
Shows only phone numbers not names as my friend experienced with it.
just got my hand on the korea set, yet also seeing numbers only for those numbers that i saved +65.
is there anyway to overcome this problem?
if i'm gonna delete one by one for all my contact , i think it will take very very long.
Oktechie
i told my friend the solution posted here. she removed +65 one by one. or as mentioned used google phone.
I'm currently using note 20 ultra HK set myself so can't help you more.
waynester
Yes it is in 5G/LTE/3G/2G auto connect. I call up Singtel the cso say not all place is 5G covered.....
Does Lte+ consider 5G? if we are not using 5G speed singtel will still charge the monthly subscription but how we know whether N20U korean set can support singtel 5G anyway to find out?
Laserng
Mine is also SM-N986N. Not sure if the phone 5G been activated by its korean telecom. FYI, When powerup my phone, it shows SKT-5GX logo. Can check yours?
